"Loading Radio" Problem
compuz1
Posts 6
compuz1 Posted: Fri, Jan 25 2013 12:36 PM
My Beosound 5 Encore continually displays "Loading Radio". It has done this for over 72 hours at a time.  When this happens I am unable to have the BeoSound5 complete MOST calculations or scan my NAS for new songs.  When I unplug my WAN port on my router, the Beosound5 behaves normally again.  MY unit has been swapped twice and I have had the same problem.  I am using a wired network and have not had this problem before.  Is anyone else experiencing this issue?
Barry Santini
New York
Posts 543
compuz1:
your router may be an issue, or check whether you have a drive letter assignment conflict for the BM5
mbee
Paris, France
Posts 1,842
mbee replied on Fri, Jan 25 2013 1:42 PM
I have the same problem (basically no connection) when my Beosound 5 is plugged on the same switch than my Apple TV... Strange!
If I disconnect the Apple TV and use it wirelessly, no problem at all.
Do you have an Apple TV connected? (or any equipment that, when turned on, causes problem with the BS5E) ?
Is the Apple TV an enemy of the BS5E??? Cool
1983beo
Posts 127
1983beo replied on Tue, Jan 29 2013 8:50 PM
It's the router that is the problem. Trie to activate the NAT in the router.
Or change the router for example a linksys router and the problem is solved.
Page 1 of 1 (4 items) | RSS
