Beocenter 9500 - how to change the saved parameters? (level sound, bass, treble, balance, loudness)
This post has 3 Replies | 0 Followers
Sventchik
Posts 43
Sventchik Posted: Sun, Dec 20 2020 3:46 PM
We are happy owners of a few beocenter 9500.
What we noticed, each beocenter has different settings for the sound when it starts : sound level, bass / treble correction, balance setting, loudness activated or not.
If during playing we change those values, they are not saved when the beocenter is stopped, they remain as previous.
So how to change & save? Thanks for support 😉👍🏻
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Dec 20 2020 3:57 PM
Press
STORE
SOUND
STORE
if memory still serves.
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Dec 20 2020 7:37 PM
Martin's answer relates to storing the levels using the remote, but if you want to do so from the control panel, press  PROGRAMMING SOUND STORE
You can also adjust the volume before you switch the system on, if for example you wish to turn it on at a lower level than normal/preset.  On the control panel, press SOUND,  then adjust the volume, then select the source.
Sventchik
Posts 43
Sventchik replied on Mon, Dec 21 2020 8:29 AM
Thanks to both!
Page 1 of 1 (4 items) | RSS
