hi I am struggling to set up the beo5 remote to my system.i purchased with zones already programmed to it and don't know how to remove and put on my one settings. any help appreciated.
You will need a copy if the Configuration Tool. You will also need a Windows PC and if I recall, it needs to be a 32bit PC.
This link may help https://archivedforum2.beoworld.org/forums/t/13349.aspx
Stoobie
