B&O Beogram Rx arm won't activate
This post has 10 Replies | 1 Follower
BigSammy
Posts 7
BigSammy Posted: Mon, Dec 21 2020 5:05 PM
My turntable has been working flawlessly up until this morning. I tried to start it normally...the record turns, but the arm doesn't activate. Please help!! Life with no vinyl is not possible!!!
Spassmaker
North Germany
Posts 223
Hi Sammy
If you need help, we need some more information about what kind of RX turntable.
TX 1 or TX 2 ?
Merry Christmas
Chrischi
BigSammy
Posts 7
BigSammy replied on Wed, Dec 23 2020 4:08 PM
I do need help! How/where can I find the information you need?
BigSammy
Posts 7
BigSammy replied on Wed, Dec 23 2020 4:10 PM
It says model 5773 on bottom. Does that help?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Dec 23 2020 5:30 PM
The model is printed on the front of the deck.
Did you try with a record on the platter?
BigSammy
Posts 7
BigSammy replied on Wed, Dec 23 2020 6:36 PM
I did try. It has been working fine for years. Suddenly, platter turns, but arm doesn't activate.
All it has printed on front is Beogram Rx
Dillen
Posts 13,191
Dillen replied on Wed, Dec 23 2020 6:57 PM
Oxidated switch contacts inside, would be my guess.
BigSammy
Posts 7
BigSammy replied on Wed, Dec 23 2020 7:04 PM
So how do I open the thing up? I can't find a service manual online anywhere, and the owner manual is useless...
BigSammy
Posts 7
Dillen
Posts 13,191
Dillen replied on Thu, Dec 24 2020 7:02 AM
Take off the platter and the cartridge.
Pull the Beogram 10cm forward out over the edge of a table.
Remove two screws from below.
Swing the tonearm 45 deg inwards.
Lift the top alu surface at the front edge and pull it out a few cms. Just enough to take up the switch for the front panel and undo the plug.
When putting it back together, make sure not to trap any leads in the right side screw fitting.
BigSammy
Posts 7
BigSammy replied on Thu, Dec 24 2020 2:38 PM
Thank you...I'll give it a go sometime in the next week!
Page 1 of 1 (11 items) | RSS
