BeoSound Stage setup without Google Account - cannot get back to settings without factory resetting ?
ToeKneeAus
Posts 54
ToeKneeAus Posted: Sun, Dec 27 2020 5:55 AM
Afternoon All,
Ive installed my new BeoSound Stage (on the BV7-40 stand thanks to STB Brackets) on my LG CX 55. It looks awesome.
As we are an Apple  HomeKit home i skipped the google option on setup (used the ‘connect to airplay speaker’ option on BeoSound Setup) and all is working well. BUT the way it looks i can never get back into the B&O App to adjust the settings .... because the phone only ever saw the Stage when it was connected as an Airplay speaker.
Im thinking that i may factory reset and go the google option on setup just to have an always accessible B&O App to adjust the Stage settings.
Has anyone else gone down the path of google-less setup - and is having the same ‘cannot back into Stage setting on B&O App’ without a factory reset each time ?
ToeKneeAus
Posts 54
ToeKneeAus replied on Tue, Dec 29 2020 10:48 PM
Just to close this one off - I’d reset up the stage with Google Home steps and I can get back into the Stage settings in the App now.
The B&O help page for a google less setup on the stage needs to be a bit more explicit that yes you can set it up without google (using the airplay speaker option from iOS wifi settings) but you’ll never get back in there !!
ToeKneeAus
Posts 54
The B&O help page for a google less setup on the stage needs to be a bit more explicit that yes you can set it up without google (using the airplay speaker option from iOS wifi settings) but you’ll never get back in there without a factory reset.
Page 1 of 1 (3 items) | RSS
