Configuring Beo 1 to 11-55
This post has 3 Replies | 0 Followers
Chris Townsend
Qatar
Posts 3,531
Chris Townsend Posted: Mon, Dec 28 2020 12:18 PM
Hi all
I’ve got an 11-55 with 3 sources connected to HDMI and PUC sources. I can easily select from the source list Apple TV, sky box and Panasonic blu ray player.
My problem is now finally getting my Beo 1 to select those sources. How do I program it when pressing say Apple to operate said device? Stuck
Regards in advance
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Dec 28 2020 6:31 PM
Did you set the BV11-55 to work with the BR1?
See Settings, Product Integrations, Remote Control
Chris Townsend
Qatar
Posts 3,531
Yes the BR1 works perfectly. What I’m struggling with is getting say Apple TV to work on the tv when I press Apple TV on the remote. It’s linking them.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Dec 29 2020 4:27 AM
Chris Townsend:
Okay, but is the BV11 set to Beoremote One (not Beo4).
And how is the BR1 set? (press List, UP what does it say?)
Because that can be the root of your issue.
Page 1 of 1 (4 items) | RSS
