Beomaster 6000 quadrophonic tape/ aux
Struer
London
Posts 106
Struer Posted: Sat, Jan 2 2021 2:49 PM
Hi all,
has anyone been able to get 4 distinct cassette audio channels through the auxiliary connection in the Beomaster 6000 quad. I’m aware that the Beomaster 6000 was designed to decode quadrophonic cassette tapes but a B and O 4 channel cassette tape deck never materialised.
Is it possible to play and receive 4 distinct channels with a suitable 4 channel cassette player a 4 channel reel to reel or a digital source such as. zoom recorder through the Beomaster 6000 quad?
Kind regards,
Struer
politician
Posts 180
Yes, this is entirely possible with an analogue source featuring the correct connections, but not through the AUX connection, which is only stereo (hence the designation AUX2). You would need to use the cassette input, which is quadraphonic (hence TAPE4). As a result, I have my quadraphonic eight-track cartridge player connected to the TAPE4 input, whilst my stereo cassette and reel-to-reel decks share the AUX2 input.
Struer
London
Posts 106
Ok, thanks for this. I have played a beocord 5000 through the tape 4 in the past with all 4 speakers playing sound, but not quadrophonic sound obviously.
Do you have a phono to din converter for your various sources. I’m curious if the Beomaster would play four mono tracks
From the likes of a portable zoom recorder and encode the tracks into the tape 4 channels.
Have you a recommendation for a quality 8 track player at a reasonable price?
Do you think that one of the earlier B &O reel to reels with 2/4 channels  would work via the tape 4?
Denisc
Posts 80
Denisc replied on Sat, Jan 2 2021 8:21 PM
Hi ,Thank Politicien ,i have few 6000 and 3400 ,i use all days an 3400 quad (sorry it's my prefer but it's not the most beatiful and the touch is completely different)
Do you know if the 3400 have the same capacity with the Tape 4 ?
And do you know where i can find and 8 tape player (220v) ,this item don't exist in France .
Thank at all beoworlders
politician
Posts 180
I've never encountered a quadraphonic cassette deck in the flesh, nor any quad cassettes that could be played on such a machine. Quadraphonic eight-track cartridges are more commonplace, and I'd suggest you buy an eight-track deck instead.
Struer
London
Posts 106
Thanks, appreciated
Page 1 of 1 (6 items) | RSS
