Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Mic doesn’t work on the eclipse, port is not active. I have only set the distance on the harmony. The mic will figure the rest out for tuning. One thing that is important it to point the mic up when you measure. For measuring distance i use a laser measure and it’s accurate more accurate than either bv or bl knows what to do with. New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube: https://www.youtube.com/c/Mikipedia mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4 Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Mikipidia:Not the wrong way, just at 0 distance, the distance is iirc meant for external sources not connect to a bv but to the 50’s themselves. The apple measuring app is fairly accurate, not as acurate as a laser measure. I’ve tried it too with good succes, but i’ve also had it up to 5cm out. Not that that matters a whole lot as the distance with b&o is only done in 10cm increments. With my laser measure i measure literally from where my ears are and that’s not something you can do with an iphone unless you have someone else do it for your New: Beovision Harmony, Beolab 50's, Beolab 18's, Beolab 17's, Beolab 3's, Beosound 9000 mk3, Beosound Stage & LG, Beosound 2, Beoplay M3, Beoplay A1, Beoplay H4 gen 2, Beoplay E8 3.0 Mikipedia on YouTube: https://www.youtube.com/c/Mikipedia mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4 Old: Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
I am a bit more perplexed now after reading on Geoffs blog that setting the distance and level of the speakers should be made manually and not by using the ARC calibration. So I think the distance should be put into the speakers, but then, should it also be put into the TV? That is hard to know. Is Geoff here and might want to fill in the blanks? :)
From the blog: Regarding your question regarding automatic setup of Speaker Distance or Level using the ARC measurements: Of course, this is technically possible. However, doing so would introduce a User Interface or procedural issue. For example, we need 3 measurements for the ARC filter calculation for one zone. Which of those three measurements should be used for the distance or level? Or should we use 2 or 3 of the measurements to arrive at a best solution – or none? The only “correct” answer is to ask the user when the measurements are performed, which makes the measurement procedure “clunky”. The cleaner path is to separate the ARC measurements from the distance and level and make those independently adjustable.
From the technical sound guide:
The Speaker Distance control is used to ensure that the times of arrival of the loudspeakers’ signals at the listening position are matched, despite their being placed at different distances from the listening position. The value displayed on the menu should be the distance from the listening position to each loudspeaker. The result of this alignment is that the closer loudspeaker’s signal is delayed to match the time of arrival of the sound from the more distant loudspeaker.
Note that, since the Listening Position can be different for different Presets, these distances may not necessarily be the same from Preset to Preset.
Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Michael, You have to set the distance for sources connected directly to the 50s. But you also have to set the same distance and presets on the tv/ There’s a setup video where Geoff Martin goes through the entire calibration process from star to finish. Setting the distance to 0 will mess up the imaging of the sound. I have microphone, the 50s and eclipse to can attest to this
Beovision Eclipse 55 Brass Edition with Oak covers and Brass Orbital stand
Beolab 50s silver & Oak, Beolab 18 Brass with Smoked Oak, Beolab 18 Rose Gold with Maple Covers, Beolab 19 Black.
That video (Beolab 50 Setting up) can be found here.........and is a must-see for all of those, who want to set up the 50’s/the 50’s connected to a Bang & Olufsen tv by themselves:
https://youtube.com/playlist?list=PLRPmJ785xnMi0nBHAKH25GbHItnj_1E8Q
However.....
Millemissen:However..... There is a tv - and there is a BV.
Esax:But if you use both then you have double the distance to play with on a b&o tv. Beovision 7-55 MK1 red, Beolab 10 red. Beolab 50, all black. Beolab 17 broken ice. Beolab transmitter. Apple tv4 and apple express 2.
Michael:Maybe the speakers don’t use the distance in the speakers when used with powerlink input? Who knows for sure though? A lot of contradicting info here Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
My experience (from long time back)
1. Set up Eclipse, BL90, BL3, no sound bar in the menus
2. Set up BL90 in the App (the 90s also talk to the Eclipse on the fine tuning)
3. I have almost a 3.8m equilateral triangle, slight toe in, 0.5m from the back wall, enter measurements.
4. Calibrate for your listening pos on the ARC/beam etc
5. Fine tune the db for L/R
To me, the biggest issue are the centre speakers. They clearly stand out (in not a good way) against the BL90s. I prefer a phantom centre and I’m guessing this would remove most setup issues of distance setup?
Hi Michael,
My experience with Eclipse 65 mk1 is that when BL 50 is connected with powerlink then all sttings in the speakers menu is disconnected (left/right,distance,db control). You make all these settings ONLY in the tv.
IF you have also an external streamer connected directly to the speakers then make a special preset for this input and make all the settings in the speakers. Here you should also set latency to HIGH instead of Auto when using powerlink from a BO TV.
It is better to seperate with different presets in the speakers between external inputs directly to the speakers and the powerlink from a BO TV.
Best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
