Transmitter 1
Mrmal
Posts 2
Mrmal Posted: Mon, Jan 4 2021 12:09 AM
Hi
is anyone know if its possibly to youse power link kabel from the transmitter to the front speaker and only transmite to the 2 back speaker ?
Also Can i set 2 source as main Sound .. i want to set both my Samsung tv and my B&O playmaker to my transmitter 1 !!  But Can i ? And if yes to 2 source then what about the bottum where i Can set for B&O produkt or not B&O produkt !  I have 1 of eatch 🙈
would aprisiate if anybody know when i Can or cant do ..
Thx
regards Claus
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jan 4 2021 11:30 AM
The transmitter powerlink port is for input only, so you cannot connect a speaker to it.
That said, with a B&O TV, you could have the TV connected to physical speakers via powerlink as well to the TR1 via powerlink. The TR1 in its turn would connect to other speakers wirelessly.
If you mix B&O and third party, the B&O button must be set to ON and the priority is on PL, i.e if you start the Playmaker while the Samsung TV is also playing, Playmaker will take over automatically. This means that it is possible that the Playmaker prevents switching to the RCA or Optical port if a signal is detected by the TR1, even if the Playmaker is not playing anything, to be tested.
Page 1 of 1 (2 items) | RSS
