Beolab 3500 - problem feedback sounds
This post has 1 Reply | 2 Followers
HamishF
Posts 1
HamishF Posted: Mon, Jan 4 2021 4:39 AM
Hi all,
just got my 3500 mk1 back out after 12 years of storage. I am getting the following problem symptoms:
1. Power up standalone - no problem
2. Not connected ...using beo4 commands menu/0/4/go - quiet ticking sounds from both ends “Tchh tick tick tick tchh tick tick tick” repetitively
3. Plugin din7 to 3.5mm jack.(no device connected) - audible humm like quiet feedback
4. connect 3.5mm jack into any pc/iPad//iPhone - loud feedback overrides the sounds from the device.
Any ideas of cause and/ or solutions much appreciated.
thanks
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi HamishF,
Welcome to Beoworld!  Please can you tell us whether your speaker displays "MCL SEL" or "PL SEL" when you press MENU 0 4 GO to open the 8 pin port?
I can then advise which version of speaker you have and if a special version of the cable is needed.  If you purchased the cable from my store (https://soundsheavenly.com) then please contact me directly with your order reference code so that I can check your order and resolve the issue for you.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
