CD player fault on my Beocenter 8500
This post has 14 Replies | 1 Follower
Type2702
Denmark
Posts 12
Type2702 Posted: Wed, Mar 14 2012 9:36 PM
Dear every people on Beoworld.Smile
My cd player fult on my BC8500. The cd mekanise its at CDM 4/57 the cd start very fast at after short it stop at open the top gate again. I think lazer itis okay, because there are a red ligyte into in, but the motor spin ekstreemly fast, can one of you maybe help me?
With kindly regards
Henrik
Denmark
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Wed, Mar 14 2012 9:42 PM
I'm not an electronic tech boy but I had the same similar issue. On the old forum (where pictures are dissapeared!!!) I saw that one specific elco (capacitor 2103) on the CD boards has to be replaced. So I did, and guess what?Smile
Brengen & Ophalen
Type2702
Denmark
Posts 12
Type2702 replied on Sat, Mar 17 2012 2:12 PM
hey Keith thank you for the tip, but dont work that I repalce 2103 capitor, so  I thnik what can be wrong?
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Mar 17 2012 4:21 PM
Wow, got a new name, KeithBig Smile
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Mar 17 2012 4:22 PM
Anyone else? Now I'm stucked helping Henrik...
Brengen & Ophalen
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Sat, Mar 17 2012 4:23 PM
It has to be a specific 2130 capacitor, I suggest you contact member Dillen
If you think nobody cares, try missing a couple of payments.
Type2702
Denmark
Posts 12
Type2702 replied on Sat, Mar 17 2012 4:33 PM
okay du you mean i shall try to replace 2130 capacitor?
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Sat, Mar 17 2012 4:39 PM
Type2702:
It's actually C2103 and can be read about HERE
I'm hoping that link works, I haven't tried linking to the old forum before.
Type2702
Denmark
Posts 12
Type2702 replied on Sat, Mar 17 2012 4:57 PM
I have try to replace the 2103 with a 33uf capitor, bur dint stil work  SadSomeone here they have repair this problem befor on BC8500/9500 before, and can the problem only be on the servo print or can the decoder print give that problem about too fast motor?
Stonk
Marlow, Bucks, UK
Posts 2,070
Stonk replied on Sat, Mar 17 2012 5:03 PM
Type2702:
As long as the replacement C2103 was the blue Philips axial type, exactly as the original and not another manufacturer then I can't advise further. Hopefully Dillen or Joeyboygolf can suggest the way forward.
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Mar 17 2012 5:20 PM
Brengen & Ophalen
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Mar 17 2012 5:53 PM
If the CD spins EXTREMELY fast, like it was part of a jet engine, it's most likely a problem
with the transistors that control the spindle motor.
It has been seen before and, strange enough, it almost always spins in the wrong direction.
Can you provide a photo of the servo board for us to look at ?
Type2702
Denmark
Posts 12
Type2702 replied on Sat, Mar 17 2012 6:37 PM
Hey Martin, thank you for your respons, that a good point you say about bad trasistors. I find a old foto her from Beoworld that eksactly the same servo board in my BC8500. It s the latest cd unit ther was use in BC 8500/9500 call CDM 4/57.
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Dillen:
I don't believe that these symptoms will be cured on the servo board.
I have cured several like this by replacing the CD Interface/Decoder board 31 although I could not find a fault on the boards.
Some of the IC's on this board do seem to run quite warm but cooling spray did not help. Might be bad solders?
TJ thinks it could be a transistor on the underside of the board but was unsualy non forthcoming.
I would be interested in your thoughts on this.
Regards Graham
Dillen
Posts 13,191
Dillen replied on Sun, Mar 18 2012 7:36 AM
There are so many different (but quite similar looking) servo boards around.
The board shown in that photo does not have the transistors, I am referring to
and is not the type of board that I have seen make this fault.
Page 1 of 1 (15 items) | RSS
