Beovision Avant 55 2014 - Apple TV 4K 60hz problem
This post has 9 Replies | 1 Follower
Robert_A
Posts 41
Robert_A Posted: Thu, Jan 7 2021 8:29 PM
Hi
I just bought a used Beovision Avant 55 2014 model from a B&O dealer. The software is the latest, and hdmi port 1 supports hdmi 2.0 and hdcp 2.1. The screen should therefore handle 4K 60hz SDR, but my Avant only supports up to 30hz. When I try 60hz SDR, half the screen turns green. B&O support in Denmark thinks there is something wrong (defective internal cable that is limiting the input from the HDMI)  The dealer don´t agree and thinks there's nothing wrong... So I'm confused. Anyone in here who has an Avant55 from 2014 that uses Apple TV 4K 60hz SDR that works? Best regards Robert
Michael
Sweden
Posts 2,578
Michael replied on Thu, Jan 7 2021 8:52 PM
Robert_A:
Hi
Have you tried another hdmi cable? I had no issues with this on my Avant 55 mk1. But you can’t use hdmi 4:4:4 perhaps.
Robert_A
Posts 41
Robert_A replied on Thu, Jan 7 2021 10:05 PM
Hi Michael!
Thank you for your reply! The cable I use is Belkin UltraHD 4K Hdmi. I have also tried with another cable with the same result. The chroma is on 4:4:4 when the output is 4K 30hz SDR and it works. When I try 60hz, it dont work with chroma 4:4:4 or 4:2:0
Michael
Sweden
Posts 2,578
Michael replied on Thu, Jan 7 2021 10:49 PM
Thats weird. I used the original Apple hdmi cable that is not anymore available but it worked in 4:2:0 SDR 60Hz 4K.
Maybe power cycle both your tv and Apple TV?
Also, are you sure the tv has the latest firmware version? Maybe the current one isn’t available online anymore and the tv is stuck on an older one? That would make sense perhaps as the tv might then be limited to 30 hz. I don’t remember exactly all the turns it all took but I had a ps4 Pro connected to one of the other ports and it would also do 60 hz but not with hdcp content perhaps.
Sorry I can’t be of more help.
andybandy
Posts 164
Why the dealer not listen to B&O denmark that have the expertise on this?
if they say it some internal cable wrong, let the dealer repair it as denmark recommand.
 It should be and easy fix if denmark support the deale how to repair.
Robert_A
Posts 41
Hi Michel
All I need is someone to verify that Beovision Avant MKI should work with Apple TV 4K 60hz SDR - and you helped me with that. Thank you very much! The firmware is the latest - that is verified by B&O support in Denmark.
Best Regards Robert
Robert_A
Posts 41
Hi Michel
Best Regards Robert
Michael
Sweden
Posts 2,578
Michael replied on Fri, Jan 8 2021 11:58 AM
andybandy:
if they say it some internal cable wrong, let the dealer repair it as denmark recommand. It should be and easy fix if denmark support the deale how to repair.
There is no internal cabling on Avant, it’s only the way with eclipse and harmony as they use an external panel instead of an integrated one.
The first five hdmi on Avant is soldered to the board. Only the sixth port has mini coax cabling to it. But that is a 1080p port only anyway.
Michael
Sweden
Posts 2,578
Michael replied on Fri, Jan 8 2021 11:59 AM
Robert_A:
Hi Michel
Best Regards Robert
No problem, good luck with the tv!
Gary
Dublin, Ohio
Posts 108
Gary replied on Fri, Jan 8 2021 4:26 PM
I will second that statement. The Apple TV 4K 60hz SDR definitely works seamlessly with the Avant 55" Mk1
Page 1 of 1 (10 items) | RSS
