Converting 2300 one-way to a two-way version done :)
This post has 0 Replies | 0 Followers
Weebyx
Denmark
Posts 1,213
Weebyx Posted: Sat, Jan 9 2021 2:38 PM
Got an idea last, I have had a IR PCB from a two-way 2500 lying around for some time, and at one point I had a 2300 two-way, which I read the SW out of before selling.
Now I have a "test" 2300, which I use for all kinds of tests of lasers and so on, and tried to install the two-way IR pcb, and then burn the 1.1 two-way sw I had to an empty EEPROM, and voila, now the 2300 is two-way :)
Off course to be correct, I should cut a hole in the bottom where the sender diodes are, since they are very restricted.
But it was just a test, and it is possible :)
/Jacob
Page 1 of 1 (1 items) | RSS
