Beosystem 3 not showing picture on non B&O tv
This post has 9 Replies | 1 Follower
oim1212
Posts 35
oim1212 Posted: Sun, Jan 10 2021 6:34 PM
So I recently got my hands on a second hand beosysten 3. I am going to use it as an sound processor only. But from what I understand you need to hook up the beosystem 3 to a screen in order to set up the speaker positions etc. so I bought an adapter (mk1 so no hdmi out) so I could connect it to my newer 4K tv, and it would also confirm that it is working. But I cannot get it to show the menu on the tv, I have an “eye” connected and beo remote 4 so I suppose it should be able to receive the signal from the controller. Does anyone know what the issue may be. Thanks for the help best regards Mio
frog
Camberley UK
Posts 624
frog replied on Thu, Jan 14 2021 8:10 PM
I believe the issue is that the beosystem 3 is expecting a beovision connected to it on the serial port. Luckily (as I remember, you just need to short a couple of pins on the MONITOR connector - the middle two on the bottom 'thinner' set - the one with the 4 pins - not the 5 pins.
Doing that, then the screen should fire up. you then have to go into the service menu and set monitor autodetect off and set it up as a non-B&O monitor.
Good luck!
oim1212
Posts 35
oim1212 replied on Thu, Feb 18 2021 1:02 PM
Thanks for the answer, what do you mean by short ? Can you describe how I do that. Sorry for the late answer
oim1212
Posts 35
oim1212 replied on Fri, Feb 19 2021 12:42 PM
Does anyone know ?
Kurzschluss
Posts 8
https://images.app.goo.gl/vwhBGyeH39ubAyqTA
Shorten pin 2 und pin 3
Guy
Warwickshire
Posts 2,590
Guy replied on Fri, Feb 19 2021 1:29 PM
oim1212:
In this context, 'short' means simply to connect the pins together.  Best to do so using wire/solder inside the connector (solder side).
From the diagram and explanation, it appears to be pins 7 and 8 that you should connect, rather than 2 and 3.
kallasr
Germany
Posts 2,562
kallasr replied on Fri, Feb 19 2021 1:32 PM
This refers to Beosystem 2 only (shorten 2 pins).
It should work with Beosystem 3 out of the box - if you there is autodect screen/display availabe in the menu... do not remember if this has to be turn on or off. Search the forum. So you might need a BeoVision 4 screen just for the initial setup...
Any chance you can conect a monitor via DVI to the output of the Beosystem to test it first?
Ralf
oim1212
Posts 35
oim1212 replied on Sat, Feb 20 2021 1:13 PM
Thanks for the great responses! I have connected a beolink active to the beosystem and can now turn it on(via controller commands). So now the eye turns green, but I still don’t get a picture to show in the tv! It seems that shortening only would work in beosystem 2 I suppose. Any ideas how u should proceed now ? Should it not just show picture on my tv since I have it connected through the dvi
OldJack
Split
Posts 371
OldJack replied on Sat, Feb 20 2021 2:39 PM
Make sure to connect your tv to DISPLAY 1 output.Display2 is assigned for 2nd display(projector).
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
oim1212
Posts 35
oim1212 replied on Sat, Feb 20 2021 3:56 PM
Yes i have tried both
Page 1 of 1 (10 items) | RSS
