Beosound Ouverture System.
Hi I need to remove the bottom back panel of my system so I can get to the lithium battery which needs replacing.
Could I please have some advice of how to remove the panel as I can’t figure it out.
Thank you for your help.
Thank you so much for your hugely helpful and speedy response. It is much appreciated - thank you again 😊
Thank you so much for the incredibly helpful and speedy response to my query. It is hugely appreciated - thanks again 😊
