BeoLab 17 + Stereo Hub
This post has 16 Replies | 0 Followers
charlessims
Posts 13
charlessims Posted: Wed, Jan 20 2021 4:33 PM
Hi Beoworld,
Wanted to make a post to confirm that Beolab 17's are compatible with the System Audio Stereo Hub, all through WISA.
It was the perfect solution to me wanting to connect them to a non-b&o tv. However, I was very unsure when getting both items incase there was some reason they would not work together.
CB
> You are Here <
Posts 1,762
CB replied on Wed, Jan 20 2021 6:05 PM
Hi
Thank you for your feedback !
Could you explain what do you call “System Audio Stereo Hub” please?
I know the Beoplay S8 connection hub...
charlessims
Posts 13
It is a WISA connection hub. Speaks to the beolabs totally wirelessly.
Here is the link  https://system-audio.com/product/stereo-hub/
CB
> You are Here <
Posts 1,762
CB replied on Wed, Jan 20 2021 9:01 PM
Thanks, wasn’t aware of this.
Are you able to use the SA Room Service too? (room correction)
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Jan 22 2021 5:44 PM
More information here:
https://www.soundstagesimplifi.com/index.php/equipment-reviews/137-system-audio-legend-5-silverback-active-loudspeakers-and-stereo-hub-wisa-transmitter
Reading between the lines, other than SA Wisa speakers can be used as well with Room Service to calibrate the Stereo Hub.
Interesting device.
corle48
Posts 7
corle48 replied on Mon, Mar 1 2021 8:49 PM
Hello
I've juste receive my stereo hub, to drive my beolab 18 (and 19)
I follow the instruction to pair the speaker and they are connected.
The problem is that they both play right channel and I can't find how to dispatch channel.
On beolab I can just select "wireless" but not a channel
I don't have try setup the subwoofer yet until stereo isn't ok.
So, is there an GUI (google home, ip acces to hub ...) which can allow to attribute channel on connected devices ?
For now, this wisa standard, doesn't seems to be as easy as it's said....
Thanks for feedback
charlessims
Posts 13
With my 17s  they auto assigned left and right. Have you updated the firmware on the hub? This was a must for me
Ekopf
Posts 10
Silver Member
Ekopf replied on Tue, Mar 2 2021 6:25 AM
Is it also possible to hardwire the Beolabs?
For some reason I don’t like using WISA.
charlessims
Posts 13
Yes it is. I have personally never tried it and don’t have the cables to give it a go. You can connect them using powerlink cables. The only issue is the input, they have an analogue input but the digital input needs to be from a bang and Olufsen source.
therefore it depends on what you wish to connect them to
corle48
Posts 7
corle48 replied on Tue, Mar 2 2021 12:12 PM
Hello,
How can you do this ? where to find the update ?
charlessims
Posts 13
You need a USB stick to plug into the back of the hub.
Instructions are here: https://system-audio.com/new-software-updates-for-silverback-and-stereo-hub/
If not I would suggest resetting the hub (making it forget the speakers) and pairing again.
I believe it should assign each channel to a separate speaker by itself
corle48
Posts 7
corle48 replied on Wed, Mar 3 2021 3:48 PM
Hello
Even with last update the problem still here
From AS , I ve answer that from them the channel is selected on the speaker, and from BO it's done on the streamer (TV or other)
Definitively not compatible for now. Maybe in a few time
charlessims
Posts 13
I have been doing some research.
I looks to me WISA Left/Right channel selection is based on the speakers MAC address and can hence be changed.
You might be unlucky that both of your speakers are assigned to the same channel. However, it seems this can be changed. B&O will be able to change this or you can yourself.
This manual might be a good place to start: https://www.primare.net/wp-content/uploads/2020/07/WiSA-User-Guide-Update-2.pdf
lvdb
Posts 7
lvdb replied on Sun, Apr 18 2021 3:36 PM
Hi there,
Any update regarding the connectivity between your B&O speakers and the Stereo Hub. Also curious how to tackle the cross-over between the 18 and 19 with the stereo hub.
Cheers.
bbhewee
Posts 1
bbhewee replied on Mon, Aug 23 2021 11:09 AM
Hello all. Bouncing on this to see if there are any further experiences. Thanks
CB
> You are Here <
Posts 1,762
CB replied on Thu, Sep 2 2021 2:34 PM
Hub arrived today Lets have a Party !!!
First try: the sound of my BL17 is just better, less flat, but… left channel only on both speakers Unsure
After firmware upgrading and a lot of hassle for pairing again, everything is fine now Smile
(even if I’m not sure it’s the upgrade that solved the issue)
My room:
Upgrade in sound quality isn’t obvious at first. I’ll try another calibration later to see.
The move from wired and Chromecast dongle to WISA brings its own sound improvement.
Note: I changed both speakers to the « free » position before running the calibration.
CB
> You are Here <
Posts 1,762
CB replied on Fri, Sep 3 2021 7:51 AM
corle48:
Hi
Had the same issue with my BL17s. Here is what I did:
* Reset the hub with a pin by pressing the reset button on the back.
* Reset the RIGHT speaker by pressing the reset button till you get a flashing green light (if the BL18 works like the BL17…) AND unplug it from the main. Leave it unplugged.
* Reset the LEFT speaker by pressing the reset button till you get a flashing green light. AND unplug it from the main. Leave it unplugged.
* Start configuring the hub: pair the remote and start the Chromecast process until it ask if you heard the sound.
* Plug only the LEFT speaker to the main, and immediately press shortly the pairing button on the hub. Wait a few seconds for the process to finish. Unplug the speaker from the main.
* Plug only the RIGHT speaker to the main, and immediately press shortly the pairing button on the hub. Wait a few seconds for the process to finish.
* Plug the LEFT speaker to the main.
* Press “try again” in the Google Home app in order to hear the test sound. If your hear nothing, restart the app and try again to configure the hub (not the pairing process !)
Hope this helps.
corle48:
You’re right…
Page 1 of 1 (17 items) | RSS
