Beolab 4000, would one tiny resistor stop it from working?
This post has 7 Replies | 0 Followers
berni2907
Posts 14
berni2907 Posted: Wed, Jan 20 2021 11:50 PM
Hi There
I have a pair of Beolab 4000 mk1, one of which works fine and the other powers up but no sound. I have removed the gunky foam, and the main (large) board has just one corroded spot on it. A tiny SMD 100 ohm resistor appears to have bitten the dust. Ot perhaps eaten the acid would be more correct. Would that give the symptom I describe possibly?
Two fuses were covered in a white dust, but test good.
Also what else should I change while I am there?
Thank you in advance!
Berni
berni2907
Posts 14
berni2907 replied on Thu, Jan 21 2021 11:48 PM
Hi
Picture of said resistor.....
berni2907
Posts 14
Hi
Designed-AV
Sweden
Posts 39
Quick question only, after you changed the resistor did the speaker work or not?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Common problem with early BeoLab 4000's and caused by black foam rot
Regards Keith....
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Jan 22 2021 9:25 AM
You’re lucky with this one. You might expect more damage than your eyes can see at this moment. The other one from the set will have more severe damage unfortunately. These “version D” boards are at an age by now that the foam has had years to “eat” more surfaces and traces which are probably beyond repair.
berni2907
Posts 14
berni2907 replied on Fri, Jan 22 2021 1:18 PM
Hello
Actually, much to my surprise, yes it did! I was pretty happy!
That 100 ohm resistor must be part of the circuit that wakes up the speaker when it detects an input.
All the best
Berni
berni2907
Posts 14
berni2907 replied on Fri, Jan 22 2021 1:20 PM
And thank you very much for your input guys!
Page 1 of 1 (8 items) | RSS
