Beplay M5 not connecting to Google Home App
This post has 4 Replies | 2 Followers
SB
Posts 5
SB Posted: Mon, Jan 25 2021 7:42 PM
I am having issues connecting my Beoplay M5 to the google home app.  I have the latest speaker software, M5 is showing in the B&O app and the speaker has been set to Chromecast enabled. I have a Chromecast enabled Naim-Muso that shows in the Google Home app. The M5 connected once after a reboot protocol, and now it is not showing at all in the Google Home app.  The M5 speaker works with Spotify connect.
I have done factory reset and it is connected to my WIFI network and it is bluetooth enabled.  Every other chromecast enabled speaker I have appears in the app, paired, but not the M5.
Any help would be greatly appreciated.
  • Filed under:
Stan
Chicago-area USA
Posts 869
Stan replied on Mon, Jan 25 2021 8:05 PM
There's another thread going on about this, not specifically for the M5, but more generically across of the Chromecast products
https://archivedforum2.beoworld.org/forums/t/45567.aspx
Long story short, it appears to be broken by some changes recently made by Google, and hopefully we'll see an update to fix it soon.
SB
Posts 5
SB replied on Fri, Feb 5 2021 10:06 PM
Just wanted to inform the Forum members, I did a call with Google chromecast tech support who did an assessment, identified the chromecast version on M5 was an old version. They send me the logs and I sent it to B&O support team. They acknowledged the issue and said they are working on it. As of yesterday my M5 dropped out of my network. I reset it by unplugging and re-plugging it. I assumed there might have been a software update (I have set my M5 for auto software update).
All issues are now resolved. M5 is connecting to Google Home and I can add it to my speaker groups. All working well.
I have to comment both Google Chromecast tech support and B&O customer support. They were both extremely helpful resolving this issue, and grateful for sending them detailed logs from my systems to resolve this issue.
SB
Posts 5
Snorreme
Posts 4
Snorreme replied on Sat, Feb 13 2021 11:12 AM
I have been following this thread as I have a M5 with Theas issues.
Seemd to be fixed, but it is so unstable that the M5 is almost useless.
After reboot the M5 shows up i Spotify, Tidal etc, but wont play. Sometimes it works after trying to connect for 5 minutes.
Anyone have the same experience?
Page 1 of 1 (5 items) | RSS
