Hi all,
I have recently swapped out my old wyrestorm hdmi matrix for a second hand Atlona which has so far proved to be more reliable. Does anyone have the remote codes in a beo5 XML file for the Atlona matrix AT-PRO3HD66M to allow me to change matrix source over IR from the beo5? (Not via the beovision integrated matrix option) The matrix has 6 inputs and 6 outputs. Any help would be much appreciated!
Many thanks,
Rob
Atlona have kindly supplied me the IR HEX codes for the matrix so I'm going to give the "beo5 3rd party config tool" for the ipad a go. It looks like it can take pronto codes as the input and convert them to the beo5 XML format. Keith kindly converted the wyrestorm hex codes for me last time round using his own program, I don't think this is publicly available though?
Here are the HEX codes Atlona supplied:
Power On
0000 006D 0000 0022 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 05ED
Power Off
0000 006D 0000 0022 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 05ED
Input 1
0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 05ED 0156 0056 0015 0E45
Input 2
0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 05ED 0156 0055 0015 0E45
Input 3
0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 05ED 0156 0056 0015 0E46
Input 4
0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 05EE 0155 0056 0015 0E46
Input 5
0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0015 0015 0040 0015 05ED 0156 0055 0015 0E45
Input 6
0000 006D 0022 0002 0156 00AB 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0040 0015 0040 0015 0040 0015 0040 0015 0040 0015 05ED 0156 0056 0015 0E46
I can confirm that I have just converted your HEX codes to an XML file which is attached.
I can confirm that I used my own program which I wrote sometime ago when the Beo5 had just been released. I have only released it to one Beoworld member who was going to review it for me.
Regards Keith....
Keith Saunders: I can confirm that I have just converted your HEX codes to an XML file which is attached. I can confirm that I used my own program which I wrote sometime ago when the Beo5 had just been released. I have only released it to one Beoworld member who was going to review it for me.
Very kind of you Keith, thank you very much. That has saved me a lot of time not having to mess around with the ipad too. I'll let you know how it goes.
Rob.
Worked brilliantly, thanks Keith
