Hello
I have just coonected my Beosound Ouverture to aux. However I am realising that I cann't switch to AUX. Probably the button is not working, and the Beolink doesn't have an aux button on it, nor through the list.
Any ideas how I can get aux to work, switch to it?
Best!
Devran Gozen
devran:Hello I have just coonected my Beosound Ouverture to aux. However I am realising that I cann't switch to AUX. Probably the button is not working, and the Beolink doesn't have an aux button on it, nor through the list. Any ideas how I can get aux to work, switch to it? Best! Devran Gozen
If you are using a Beo4 remote then it's actually A.AUX (not just AUX) that you will need to add to the LIST function.
Alternatively, if you put the Ouverture in A.OPT 2 then you can select A.AUX with any of the video source buttons (TV, SAT, V.TAPE etc).
If the AUX button on the Ouverture's keypad isn't working, are other buttons working? There is quite a common fault with these keypads. Try the digit 6 and/or the LOAD button - this will narrow down the fault.
EDIT: Instructions follow, if required:
To add A.AUX to the LIST button on the Beo4:
- Press Power and LIST together, the display should read ADD?
- Press GO.
- Press LIST until the display shows A.AUX. then GO.
- A.AUX should then be listed under LIST. Select this and then press GO to send the command to the Ouverture.
Secondly, if you do want to put the Ouverture in A.OPT 2:
- Turn to standby/off.
- On the Beo4, press the POWER button and LIST together. Then press LIST until OPTION is shown, press GO (centre button), and then press LIST to show A.OPT. Then press 2. The power light on the Ouverture should blink to show that it has been accepted.
Hi Guy,
Thank you for your reply. I acutally am only assuming its a Beo 4, but it looks like in the following link:
https://ibb.co/VjY20Gh
On this one I can't locate any aux related buttons, or shift, or a.opt2 or a.aux
Have any ideas?
devran: Hi Guy, Thank you for your reply. I acutally am only assuming its a Beo 4, but it looks like in the following link: https://ibb.co/VjY20Gh On this one I can't locate any aux related buttons, or shift, or a.opt2 or a.aux Have any ideas?
Yes that is an early Beo4. You should be able to add A.AUX to the LIST as follows:
On the Beo4:
- Press Power (Red button) and LIST together, the display should read ADD?
- Press LIST repeatedly until the display shows A.AUX. then GO.
- A.AUX should then be listed under LIST. Select this and then press GO to send the A.AUX command to the Ouverture.
I just had another idea: An alternative way to select the AUX input would be to press AV then TV using that remote. Worth a try!
YOU ARE AMAZING!! THANK YOU!
Not sure which solution worked (perhaps all of them), but thanks anyway!!
The verified answer this worked:
^ Oh good - thanks for letting us know!
Come back on the forum if you need more help
Hi Carolpa,
I connected it to my airport express through aux for airplay. It’s more convenient but it kills the feeling I was getting from CDs
