Beogram 1500 needle/cartridge
NickA
Posts 4
NickA Posted: Wed, Jan 27 2021 7:16 PM
Hi Beo people,
I’ve recently acquired a Beogram 1500. It’s the one with a teak surround and the amplifier built in.
It currently has an SP 6-7 Cartridge in the arm, but the needle has broken-off in the cartridge. So, should i buy a replacement needle for the cartridge (if I can find one), or buy an alternative cartridge with needle in situ? I see a lot of SP12 and SP14’s advertised, but would either of these work or be compatable with the deck I have? Would they be an upgrade from the SP 6-7? What do you suggest i buy.
Also, although the power light, lights-up when i press the ‘on’ phono button, the turntable doesn’t turn, so I’d like to get the entire Beogram serviced. Can anyone recommend a good service centre or B&O expert i could take it to please?
I’m in SW London so somewhere local would be great, but not essential.
Thank you!
ozzotto
Posts 1
ozzotto replied on Sun, Jan 31 2021 12:35 PM
I am also looking for a cartridge for Beogram 1500. So far the only solution is Sound Smith but it is based in USA. There are also some used MMC20 cartridges available in eBay. I am not familiar thought with the SP cartridges you mention.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 31 2021 1:35 PM
Have you tried taking the tonearm out from its rest?
That's where the switch for the platter motor is.
SP14A would be an upgrade, but a good SP7 should give almost equally good performance.
NickA
Posts 4
NickA replied on Mon, Feb 1 2021 10:30 AM
Thanks for your replay. As far as I understand it, the Beogram 1500 came with amn Sp6-7 cartridge, later models came with an SP12, SP14 or something similar?
N
NickA
Posts 4
NickA replied on Mon, Feb 1 2021 10:33 AM
Thanks for your response.
Yes, I fiddled about quite a bit with the arm etc, but no movement on the tunrtable. Thanks for the info on the Sp cartidges... What about the Sp10 or 12? I see alot of those advertised on Ebay? I do still have the original Sp6-7 cartdige... but the needle is broken. Maybe I'll just get a new needle. Do you have any suggestions for a needle at all? Either the type, or a source to but one from?
Thanks for your help.
N
Page 1 of 1 (5 items) | RSS
