Beolab 5 Conservation for the future and technology upgrade project
This post has 6 Replies | 2 Followers
Eriperi
Posts 32
Eriperi Posted: Thu, Jan 28 2021 6:33 PM
This is only an imagination project for now but I thought I share my ideas because  BL5 owners will get replacement parts issues in the future.
one of my BL5’s has intermittent themal protection issues and the frequency of the issue is increasing, because the spare parts seem to get out of stock in the (near) future I have been looking at other ways to keep using this magnificent speaker.
in another thread I saw that the main board basically consists of a power supply, the central DSp unit and 4 separate ICE modules, these seem to be the standard 1000a and 250a ICE modules which I have bought in the past for custom applications.
so the power supply is repairable or replaceabke,
the Ice modules are still being manufactured and can be purchased for PA applications but they are exactly the same as the ones in the BL5:  https://www.profusionplc.com/featured/icepower-amps.php?gclid=EAIaIQobChMIs8XhlKC_7gIVN4ODBx1SrQkeEAAYASAAEgJZu_D_BwE#a-series
The DSP and crossover part is not something you can buy or easy make your self but technically you should be able to swap it with a Minidsp 4 way crossover and use dirac live for room correction.
https://www.minidsp.com/products/dirac-series/ddrc-24
altough this will be quite a hassle from cabling point of s would theoretically convert the speaker in to a Beolab 5 looking speaker with many of the Beolab 50 functionality and room adjustments.
any one ever considered this?
laseralex
Posts 240
laseralex replied on Fri, Jan 29 2021 7:40 AM
It seems like a pretty straightforward update.  I'd be doing roughly the same if I owned Lab 5s.
I actually have a ddrc-24 on my workbench right now.  I'm building a PowerLink interface for it so I can put it inline between my Moments/Essences and my speakers.  The Dirac room correction is fantastic (as tested from my PC) so I'm really looking forward to having it on all my speakers within the B&O environment.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Fri, Jan 29 2021 9:35 AM
A very interesting idea of which I started to explore with some equipment I bought after Steve's (Sounds Heavenly) film on his channel.
The development B&O has taken into the BL5 at that time must have been enormous, taken into account all the different variables, knowledge (software development) and measurements.
It will be a challenge to get it all inside the BL5 with the lowest level of DIY and personal preferences , if it has to be applicable for the rest of the BL5 owners.
I remember the time in the late 80's that I designed (Orcad-Ultiboard-etc) my own PSU to drive amplifiers used in Home based amplifiers (+ en - 40V driven STK modules). All in one cabinet at the end and placed inside the car. Worked. Very rewarding I can say. Designing, building, applying and using.
Eriperi
Posts 32
Eriperi replied on Sun, Jan 31 2021 10:29 PM
The acoustic engineering has been done for us by B&O, the cabinet is built for us and we do not need to worry about the production of the cabinet. also the cross over frequencies are known so we can copy those as well.
we probably do not know hte different output levels needed to equalize the 4 chassis’s and we will lose the adaptive bass but the Dirac software will solve this for us and proabbly much better.
the termal protection is probably more difficult but also not nessecary.
The diy MiniDSP kit is slightly smaller than an Ice module and runs on 12v. the 12v is also needed for the Ice module so this is available on the onboard power supply.
It looks like there is space for an extra Ice power on the side of the mainboard:
laseralex
Posts 240
laseralex replied on Tue, Feb 2 2021 11:16 AM
This looks great!
I’d be happy to offer my expertise as an Electrical Engineer.  I just need someone to donate a set of BL5’s to me so I have speakers to work with. 😂
* Yes, really! 🤦‍♂️
Eriperi
Posts 32
Eriperi replied on Mon, Aug 30 2021 11:50 AM
For now i chose to have mine fitted with a refurbished B&O main chassis but they were doing that i learned that this project might be easier than I originally thought. Some more I learned and just writing it down here for future reference
Crossover frequencies are: 120/600/2000hz
Cables could be reused from the original main chassis, but all cables and connecters are unique per speaker, this make the repair idiot proof.
It the 2 smallest ICE power units are replace le separate from the main chassis, I think they are normal std 250w ice units. If one of the amps fro the midrange or the tweeter is broken this is repairable in my opinion.
Eriperi
Posts 32
Eriperi replied on Mon, Aug 30 2021 12:08 PM
Looking a 2nd time at the icepower site the BL5 main chassis might be build out of the Stock icepower ASP1000 added onto that one Icepower 1000a and 2 Icepower 250a (the asp contains the power supply. (635€ combine) added to that you have the DSP unit some cooling, cables and mechanical construction to combine all of that.
the repair price was 925 per speaker so I think that is actually quite reasonable for the DSP part and the work done.
Page 1 of 1 (7 items) | RSS
