Integration of BS Core in setup
This post has 1 Reply | 2 Followers
Trust
Posts 1
Trust Posted: Sat, Jan 30 2021 10:28 PM
Hello there,
I have my Beovision 11-46 connected via Poweline/RJ to two BL-6000 speakers and a BL-11 subwoofer.
Now I bought a BS Core for streaming purposes without having to turn on the TV (control via phone).
I simply connected the BS Core to the free Powerlineslots of the BL-6000´s. It works but the sound could be better. And the BL6000´s are a lot quieter when I use my TV.
It sounds as if the Core and the TV would take power of each others inputlevels.
My questions:
1. How can I use my speakers in two different sets (Core and BV) without interference?
2. How can I also use the sub with the core?
Thanks for your help!
Regards,
Tim
Millemissen
Flensborg, Denmark
Posts 14,680
It is NOT recommented that you use the PL inputs on a Beolab speaker for two different products at the same time!!!
If you really want to have the Core seperated from the BL6000 you could use a Powerlink switch like this:
https://almando.com/index.php/almando-category/almando-powerlink-switch-stereo.html?___store=endkunde_eng&___from_store=default
or this:
https://shop.oneremote.dk/shop/69067-powerlink-switch/4162-powerlink-speaker-switch/
However, I would not recommend this in your case, because of the excellent speaker setup options in the BV11 with bas management, when you use the BL6000 with the BL11 there......creation of different Speaker Groups for different listening/viewing purposes etc,
instead I’d urge you to rethink your decition about not having to turn on the BV when listening to music - or at least tell why you don’t want to do that.
Connecting the Core to the BV11 is easy, they just have to be in the same home network - this can then be done in different ways.
One benefit here will be that you can do the basic controlling of the Core with the Beoremote just as with the tv functions.
Feel free to ask again, if interested.
Page 1 of 1 (2 items) | RSS
