Pink stripe on BV4-65
politician
Posts 180
politician Posted: Tue, Jan 29 2013 2:16 PM
My BeoVision 4 65" has developed an odd fault — a pink stripe about 4" wide and 14" long has appeared on the screen, presumably due to a section of stuck pixels. Is there any easy resolution for this, or is the screen on the way out? If so, is it normal for this to happen after less than five years' use?
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Wed, Jan 30 2013 8:39 AM
politician:
There was a similar fault described on the archived forum, but it doesn't come up with any obvious search.
This external link may give you an idea of possible Panasonic screen problems, but at less than 5 years old I'd be asking the B&O dealer for an opinion.
http://www.avsforum.com/t/1269808/vertical-black-bar-on-panasonic-42-plasma
Graham
Roger
Norway
Posts 417
Roger replied on Thu, Jan 31 2013 10:46 AM
This is a fairly well known issue and your dealer will help you out - there is nothing wrong with the screen as such: some of the electronics will need some cleaning (based on where the stripe is).
Roger
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
