B&o Master Control panel 5500 connect to beovision 10
JamesSamuel
Netherlands
Posts 51
JamesSamuel Posted: Sat, Feb 6 2021 3:02 PM
Can i connect the master control pannel to my beovision 10.
I have a beosystem 5500 connect with a masterlink converter in the beovision.
i can use the panel for radio, tape, enz. But not the volume. Because the beolab 6000’s are connect trought the beovision.
is there something possible that i I can use the panel also for setting the volume?
now i use my beo4 remote.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Feb 6 2021 3:30 PM
Master Control Panel 5500 will only work with Beomaster 5500,6500,7000.
JamesSamuel
Netherlands
Posts 51
Thanks Martin. Oke Thanks for the info!
Page 1 of 1 (3 items) | RSS
