Just can't figure out what that is on the lower left corner. I hope it's not what I'm thinking
Brengen & Ophalen
Looks like glue remains from a record cleaning brush or something.Could be a foam pad.Could be araldite.Seems a previous owner modified and/or redesigned this poor Beogram using non-original parts ...
Agree - looks like glue from a dust bug. I imagine it would be easy to clean off.
Peter
Yes, I could never understand the use of those horrid accessories...
It looks indeed like that. But the thing is expensive!
Jacques
