Hello
I have a BEOSOUND 9000 which I still use everyday.
The problem is my living room has a mezzanine and when I am on the mezzanine the remote control BEO4 doesn't reach my BEOSOUND so I can't operae it from there
Does anyone know of a way of extend the signal ? I don't want to invest in old technology so I hope to find a cheap solution.
I had found the solution offered by Powermid (Marmitek) but that works for all remote signals except B&O as B&O apperantly uses high frequency.
Thank you for your help
Bart
Something like this may work. Have this upstairs and feed an emitter downstairs. Looking at the user manual, it looks like exactly what you need.
https://w3.oneremote.dk/oneremote/admin/typer/vejledninger/78102630u1uk.pdf
Stoobie
