Do you have information about the Beocenter 2300 versions with 2-way connections?
EU 2616 (Two-way) (1991 - June 2000)GB 2617 (Two-way) (1991 - June 2000)
All the Beocenter 2300 model 2616 have a 2 way connection?
What are the differences between the Beocenter 2300 model 2616 and model 2611?
What about radial (1st gen) and linear (2nd gen) CD player of the Beocenter 2300?
According to this page: https://www.beoworld.org/prod_details.asp?pid=393
The 2616 is two-way, and the 2611 (later model) is one-way (by exclusion)
You can check if a model is two way because it has a visible IR window bottom left, below the moving glass panels.
I am not sure when the 2nd gen CD mechanism was introduced. Mine is a 2616 with the curved (rather than linear) CD pickup.
Thank you very much.
it is possible to see a photo of the IR windows?
Here it is!
Now everything is more understandable.
best regards
