All, I wanted to purchase a used B&O turntable. What would be the best option when connecting to a sound system? Thank you for your help.
What turntable were you thinking of buying? And what would you be connecting it to ?
regards
Noel
I was looking for a Beogram 3000, does it have an audio output and can I connect to a beosound 5 aux? Thank you
Any special reason for going after a Beogram 3000?
Noel.
Beosound 5 only connects to BeoMaster 5 (DVI, power, USB). (FYI- from the Beoworld page )
No special reason, just checking on what’s available on EBay. For input I was planning to use a Aux USB input converter. Thank you
