How do I make Legacy Beolab 1, Beolab 2, Beolab 8000/6000 Wisa Compatible
sodoi18
Posts 23
sodoi18 Posted: Wed, Feb 10 2021 8:52 PM
I am upgrading my TV to an LG OLED which is Wisa compatible.
 Currently, I have a Beosystem 3 – driving my surround setup:
  • From L and R – Beolab 1
  • 2 Subs – Beolab 2
  • 2 Rears – Beolab 3
  • 2 Sides – Beolab 6000
Question:
I would like to make all the speakers above Wisa compatible – is Beolab Receiver 1 an option. Is there any better, more economical option?
Hoping there is a dongle like accessory which I connect to each speaker to make them Wisa compatible?
Greatly Appreciate your help!
Thanks,
kallasr
Germany
Posts 2,562
kallasr replied on Thu, Feb 11 2021 5:35 PM
You need one Beolab Recever 1 for every single speaker...
If you have wireless lan using 5 GHz band in your home you might get issues as I had.
Limiting your wlan to 2,4 ghz can help.
Ralf
leosgonewild
Helsinki, Finland
Posts 2,373
Sounds like welcoming syncing problems...
tuttivini
Posts 186
tuttivini replied on Fri, Feb 12 2021 1:55 AM
Your LG TV is WISA compatible, but you still need a dongle, like a Soundsend or Axiim dongle.
Every Beolab needs a wisa Beolab 1 receiver (pricey!)
I wanted the same, but 5 receivers is a little to expensive for me... See my post:
https://archivedforum2.beoworld.org/forums/t/44013.aspx?PageIndex=2
Wish I could find cheaper other brand rca wisa receivers. Because it would be a perfect solution: surround sound directly from LG TV (I have a C9 oled), using the LG stock remote for volume. No extra av-receivers, processors, etc needed.
orca99
Posts 24
orca99 replied on Sat, Nov 6 2021 2:29 AM
I use R1 boxes on 5 older beolabs, and beolab 18/9’s. Klipsch hub. No latency issues ever. Geoff explain why in one of his extremely helpful articles.
(need to replace the hub as it is getting old)
Page 1 of 1 (5 items) | RSS
