Beolab 18 hissing
This post has 7 Replies | 0 Followers
jabell
Posts 24
jabell Posted: Wed, Feb 17 2021 8:49 PM
My Beolab 18s are connected via Transmitter 1/Core. They make a hissing sound with or without music. I have read that this is due to the transmitter 1 pushing excess gain to the speakers. Would I experience the same issue if I were to swap the Transmitter 1 with the Axiim link?
andybandy
Posts 164
andybandy replied on Thu, Feb 18 2021 12:01 AM
Do you have your core on wifi? If you have, try to Connect your core with Lan cable, and see if the hissing noise is gone..
jabell
Posts 24
jabell replied on Thu, Feb 18 2021 1:42 AM
Thanks for the suggestion. I will try it. Do I need to make any changes to the network settings within the Configure Menu of the B&O Core App? The network is currently assigned to my WiFI. By inserting a Lan cable, will the App automatically disregard the WiFi signal and route via Lan instead?
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Thu, Feb 18 2021 6:52 AM
jabell:
Yes, it should
andybandy
Posts 164
andybandy replied on Thu, Feb 18 2021 8:18 AM
Only put the LAN cable to your Core Ethernet connection and to your router Lan connection.
Core will priority Lan and disable wlan.
Duels
England
Posts 2,553
Duels replied on Thu, Feb 18 2021 9:32 AM
For further information my BL18s also started to hiss/crackle recently. (The only time they didn’t hiss was when I turned my core off completely and restarted it.). My speakers are cabled rather than using the transmitter 1.
Using an Ethernet cable between my core and router cured the problem.
andybandy
Posts 164
andybandy replied on Thu, Feb 18 2021 12:11 PM
Have you report it to your local B&O dealer? Its importer that everyone that have this issue report, and also tell how it fix if you have a fix :) se we all can Get this problem fast fixed..
Duels
England
Posts 2,553
Duels replied on Thu, Feb 18 2021 12:45 PM
andybandy:
If that question was for me then I don’t have a local dealer anymore. Wink
Page 1 of 1 (8 items) | RSS
