Where can I find the user manual for a fist generation (MK1?) Beocom 600? I downloaded one from the internet but it's for the newer model and the instructions on how to enter setup does not work.
There are a few in the manuals section on the main site. There's one that says "User Manual English Old" - that is the one I have to use for my Mk1 Beocom 6000.
Stoobie
Thanks for the info, but I can't access that part of the site since I am a bronze user.
If you're after service mode enter
9#9#9*DOT7
It's well worth joining as a silver or gold member to get all the manuals on site!
