Struggling to get FirestickTV to work with my Beovision 10-40. Am using HDMI port and Setup/Connections menu. Tried connecting as DVD, PC, DTV but not getting anywhere. Nothing comes up on the screen. Help appreciated. Alan
I use mine with a BeoVision 10 as V.MEM.
I can look up menu entries this week-end.
But using the manual you should be able to do it...
Ralf
So pressing V.MEM brings up the HDMI port B.
I take it you need to use the fire stick remote to control the fire stick? Does it turn on when you select that option?
Beovision 10, Beoplay V1, Beolab 17, Beolab 9, Beolab 4, Beosound 2, Beosound Moment x 2, Beoplay M3, Beogram 1700
Thanks for the replies. I've now got FirestickTV working fine and sharing the HDMI port with my Macmini via an HDMI expander.
James1980:I take it you need to use the fire stick remote to control the fire stick?
