BeoVision 8-40 - connect to WiFi for streaming
serenata
Posts 16
serenata Posted: Sat, Feb 20 2021 11:53 AM
Hello, good day - do you have a recommendation how to set up a BeoVision 8-40 (type 9560) so my mother can 'stream' through WiFi. Can I just get her a cable to go from the TV's HDMI-socket and a Wifi-module (Apple) or must it be a fixed-line from TV's HDMI to the actual router? Or should it be from SCART? Or connect a Google ChromeCast in some way (HDMI/SCART)?
Thank you, Klaas
Iceman10245
Berlin - Germany Nova Santa Ponsa-Islas Baleares
Posts 186
I have a Fire TV Stick on the TV and I am happy with it.
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass,  BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence ,  BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white,   Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
serenata
Posts 16
serenata replied on Sat, Feb 20 2021 12:20 PM
or... could I use an Apple TV perhaps?
Iceman10245
Posts 186
I also have an Apple TV on it, it works fine too
Iceman10245
Posts 186
serenata
Posts 16
serenata replied on Sat, Feb 20 2021 2:35 PM
Thank you for confirming!
mah I ask which version, exact connections and any special connection settings required?
herzlichen dank Im voraus
mfg, Klaas
Iceman10245
Posts 186
I do not know that I made any special settings, except assigned the port
Millemissen
Flensborg, Denmark
Posts 14,680
serenata:
mfg, Klaas
These are merely external devices - that you set up to a HDMI port on the 8-40 and assign a button to on the Beo4.
Any other configuration e.g. connecting to the network, wireless or wired etc is done in the device = with the ATV in the user interface on screen with the Chromecast via the Google Home app.
Note! If you want to control the user interface of the ATV with the Beo4. you will need the suitable PUC codes installed on the BV8 and the ir cable.
Since there is no user interface on the screen using the CC, there is nothing to control there (apart from the volume).
And afterwards you of course control the volume with the Beo4.
Page 1 of 1 (8 items) | RSS
