Hi folks,
Thanks to the reviews and discussions on this forum I've been able to educate myself and make more confident decisions about my previous B&O purchases. But for the first time I'm feeling indecisive, and therefore thought I'd ask the community for some advice.
I've managed to secure a sweet deal on a used, 2-year-old Beosound 1 (Gen 1) for 650 GBP. This is considerably cheaper than the price I would pay for a brand new, newer (Gen 2) model. From what I understand, thanks to recent firmware updates, the sound quality difference between Gen 1 and Gen 2 models is minimal.
However, with the recent release of the Besound Level, which sits in the same price range and shares a similar use case, I wonder if it's still worth to purchase a Beosound 1 (Gen 1), an almost 5-year-old speaker.
Should I go for the Beosound 1 Gen 2 instead, even if this means paying nearly twice as much? Or should I dismiss both and go for the Beosound Level as it uses newer technology and, although the lower price, sounds similar if not better?
Any thoughts are appreciated.
Our Beosound 1 is a Gen.1 and lives in the kitchen.
As I still think it's one of the best looking wireless speakers B&O have made and I prefer to talk to people rather than inanimate objects, I have no intention of replacing it!
At that price, I’d say for sure the BS1 Gen 1. Half off and it sounds fantastic. If you are in the price range of a new BS1 Gen 2, I would recommend the Level since it’s less expensive and apparently has a much bigger, weightier sound. That’s my only complaint with my BS1 Gen 2. It can’t really handle too much bass and loses it’s weightiness has higher volumes so I’m selective on which music is play on it.
Hi, I would recommend you the Level too.
I'm struggling with a very similar decision between the Level and a BS1 GVA which I got on sale for ~850 GBP (actually 1200 USD from the US B&O website). I've had the BS1 for about a week and the Level for a couple days. Here are my current thoughts (writing this down should help me, too).
Sound Quality:
Placement / Style:
Connectivity
Portability
Longevity
GVA
My Overall Conclusion
I'm still on the fence. If the Level had NL, it would be an easy win for the Level. If the BS1 had Spotify Connect, it would be easy win for the BS1. I'm leaning toward the Level because of the sound quality + newer platform + rumors of NL. The BS1 will never have Spotify Connect, but there is the possibility that the Level may get NL. Then again, I might buy neither and wait for the Level to actually support NL. Then again, I might keep the BS1 because it's cheaper, fits the kitchen better and is good enough. Decisions, decisions...
