Parts for Beocord 3300, beogram 1200, beo master 1600m
MalcolmH
Posts 2
Silver Member
MalcolmH Posted: Thu, Feb 25 2021 10:31 AM
Hi
I wonder if you can help me.  I am looking for the following components to repair my Bang and Olufsen Kit:
Beocord 3300 type 2942: drive belts
Beomaster 1600m type 2113: tuner cord and fitting instructions
Beogram 1200 type 5214:  SP14 stylus (or complete cartridge).
Can you please point me in the direction of someone who may be able to supply these?
Kind regards
Malcolm Hall
Malcolm.hall@btinternet.com
Normal 0 false false false EN-GB X-NONE X-NONE
loureed5
Posts 171
loureed5 replied on Thu, Feb 25 2021 11:15 AM
Hi MalcomH,
You could try : "Beoparts -Shop" (sorry , i don't know how to post a link)  but if you google it ,it will take you there.
For the belts,you could contact User Name : Dillen (Martin is his name) on this forum.(Don't be tempted to buy off e-bay,especially belts from Poland- they are not fit for purpose.)
Hope this helps,
regards
Noel.
loureed5
Posts 171
loureed5 replied on Thu, Feb 25 2021 11:37 AM
Sorry I forgot to mention "Beoparts"-  Google:  "How to buy beoparts"
This will give you other options.
regards
Noel.
Krolroger
London, UK
Posts 221
Krolroger replied on Thu, Feb 25 2021 2:01 PM
Hi Malcolm,
Martin/Beoparts is your best source for parts but you can use suitable dial cord which you can get on eBay.
The 1600M is an updated version of the Beomaster 1400 (2104).  I repaired one last year and posted this:
https://archivedforum2.beoworld.org/forums/t/41585.aspx?PageIndex=1
This includes some info on restringing the dial cord and restoring the inertia gearbox mechanism.  The restringing part of it will require nimble fingers and the patience of Job.  To get the tension right the cord loop needs to be a specific length, 160 cm if I remember right.  In the end I resorted to a slight bodge as without the correct tension the string won't drive the tuner.
Service manuals are available on this site for Silver and Gold members.
Regards,
Simon
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Feb 25 2021 4:43 PM
loureed5:
Not sure about Poland, but the ones from Portugal causes more damage than good.
loureed5
Posts 171
loureed5 replied on Fri, Feb 26 2021 12:29 PM
Sorry Martin, my mistake-I should have said Portugal.
regards
Noel.
Page 1 of 1 (6 items) | RSS
