Beogram 4002 (type 5513)
Struer
London
Posts 106
Struer Posted: Fri, Feb 26 2021 11:50 AM
Hi, I recently acquired a spare Beogram 4002 (type 5513) US Model with a 110v fixed voltage.The main board (8005016) is in cosmetically nice condition with little or no previous tampering. However not all functions work. I have determined that any faults are with the main board:
Pressing 33 rpm - record wiping function works
When pressing up or down -no response
‘’ (slow tracking both work)
Auto drop of tonearm doesn’t work
Auto change from 33/45 doesn’t work
Manual command of 33/45 work and change motor speed
(All lights operate)
On studying the manual I thought that it might be one of the transistors in the
Detector arm circuit, instead of the solenoid circuit.s
Also does anyone know if it’s possible to rewire the transfer in this unit to achieve 220/240v. I say this as I have a step down transformer
Which works but its large and adds more clutter.
Kind regards,
Struer
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Feb 26 2021 12:39 PM
All typical when it's time for a complete overhaul.
Struer
London
Posts 106
Thanks for this.
In your experience might these faults be related to the need for a recap, as each fault is specific to a different clusters on the main circuit board and but pointed to any one transistor.
I may be missing something obvious.
Every other part of the TT is now working as it should.
Dillen
Posts 13,191
Dillen replied on Wed, Mar 3 2021 4:38 PM
New capacitors, new trimmers, new relay(s).
Cleaning, lubricating, aligning, reinfusing motor bearings, new belts etc.
Struer
London
Posts 106
Thanks,
Working through issues
Struer
London
Posts 106
Hi, after much work and tests I have managed to get board working almost entirely as it should.
All buttons now work as they should and the tonearm drops where it should. The only issue (which I have experienced before In another deck)
Is a slow release of the magnet coil when it is engaged; either by pressing up or any other button.
Could this be a problem with the solenoid circuit or the electronic switch circuit?
This is not a lubrication problem
Kind regards.
Dillen
Posts 13,191
Dillen replied on Sat, Nov 13 2021 5:41 PM
Tonearm raise should not be slow.
It should be an instant click.
Struer
London
Posts 106
Yes, the fully working unit I have clicks instantly
Struer
London
Posts 106
The tonearm is Lifting as it should now.
C36 was the culprit.
Page 1 of 1 (9 items) | RSS
