Beomaster 2000 model 2911
Nielsy
Posts 4
Nielsy Posted: Sat, Feb 27 2021 7:14 PM
got my stereo out of storage, hooked it all up lit up and everything, but the volume is not working almost like it is stock just of mute turning up and down the volume will show the lines but the volume out of speakers are the same. tried a pair of headphones same deal. speaker I am using is the Beovox 802S. I had this in storage for 15 years. Hope somebody can help or point me in some direction.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Feb 28 2021 6:48 AM
Check the 100uF capacitor at the volume IC.
Nielsy
Posts 4
Nielsy replied on Sun, Feb 28 2021 9:15 PM
I am looking at this tearing my hair out. Is it possible you can give me the number of the capacitor. I can see number c22  is 100uf and number c50 is 100uf sorry for sounding ignorant, I would send it out to be fixed, the closest store is 650 km from here and when I phoned them they said they didn't work on old junk. I am a motorcycle mechanic so I know how to solder a new component on the board.
Dillen
Posts 13,191
Dillen replied on Sun, Feb 28 2021 9:58 PM
C30.
It sits from 2IC4 pin 1 to ground.
Nielsy
Posts 4
Nielsy replied on Mon, Mar 1 2021 1:12 AM
Thank you so much. I just noticed you are a Dane Tusind tak for hjælpen. Niels
Nielsy
Posts 4
Nielsy replied on Mon, Mar 1 2021 1:13 AM
Thank you so much, Just noticed you are Danish. Tusind tak for hjælpen
Page 1 of 1 (6 items) | RSS
