BeoLab 8000: which damping foam material to use for replacement?
This post has 28 Replies | 4 Followers
KolfMAKER
The Netherlands
Posts 176
Silver Member
Many B&O BeoLab 8000 owners are aware that the early 8000 models have damping foam that perishes, falls apart and gets sticky to the PCB and components.
I have such a pair now and want to clean all the foam dirt out and replace it with proper material. So I can use some suggestions:
  1. What is the foam material that B&O started using (the white damping foam) to replace the old bad foam (dark grey)?
  2. Is there any alternative, with good availability, that's recommended?
See picture of the new foam (white) attached.
Hope to hear your advice!
Beosince98
Posts 274
 I can recommend buying basotect in two different thicknesses, it worked perfectly for me.
KolfMAKER
The Netherlands
Posts 176
Silver Member
Thanks for your advise Beosince98.
Do you know the exact thickness of the thin parts en the thick parts?
Beosince98
Posts 274
KolfMAKER:
Unfortunately I do not rememberer. I guess I ordered one sheet with 1cm thickness and one with 3-4cm thickness.
KolfMAKER
The Netherlands
Posts 176
Silver Member
Thnx.
By the way, is Basotect the same damping material as what B&O is using?
Beosince98
Posts 274
KolfMAKER:
Thnx.
I am not sure if it is the material they use, but it looks/feels the same and seems to be high quality foam for exactly this application.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Tue, Mar 30 2021 3:11 PM
I found the foam material that seems to be the right fit.
It is called Basotect from BASF, based on Melamine. The characteristics make it absolutely suitable. And the structure and color of the material even look the same as the official foam kits from B&O. (Maybe it is the same)
gerard
Luxembourg
Posts 331
gerard replied on Sat, Aug 7 2021 9:58 PM
Do you have information where to place the different pieces?
My original foam , is a gluey mess.
KolfMAKER
The Netherlands
Posts 176
Silver Member
Hi Gerard,
The original foam is terrible as soon as it started deforming.
Please put the right amount of effort in cleaning it away. To my experience, it sits everywhere even where you don't see it at first hand. It is important to get it away from all components, and yes that is a lot of nasty work to do. Also check all the copper traces on the PCB. I have seen copper traces 'eaten away' and disturbing for instance the Auto Standby switching.
Here's a picture of the foam set in all the pieces (original B&O).
KolfMAKER
The Netherlands
Posts 176
Silver Member
And here is a picture where you see all pieces in the right place in the speaker casing.
So the 'round' piece goes around the bottom side of the bas reflex pipe. The middle piece is waste, is not used.
gerard
Luxembourg
Posts 331
gerard replied on Sun, Aug 8 2021 10:56 PM
Wow, THANK YOU very much for the picture!!!! Lets have a Party !!!Yes - thumbs up
Did you clean yours yourself?
Did you test different products for cleaning ? (chemicals?)
I have already had some pcb lines eaten away by the gluey foam mess.[:\'(]
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Mon, Aug 9 2021 11:33 AM
Yes, I did the cleaning myself. Not a task I like to do (understatement ;-)
For the cleaning I would recommend not to use chemicals. I never do with vintage audio equipment. I always look for eco/biological cleaning products.
The BeoLab 8000 (and other) speakers are made from aluminum and anodized. Anodizing creates a layer that makes them shine like chrome. But this layer can be very sensitive to chemicals. When it is damaged or gone because of treatment with the wrong materials, there is no way back (or you should anodize them again which is quite expensive).
So for the outside I mostly use an eco-friendly degreaser from a spray bottle. Read the label to make sure there are no chemicals added!
For the inside I use the same principle; no added chemicals. But the story is different because you have to get the sticky foam out. And it is very sticky. Here's what I do:
  1. Use a table covered with plastic you can throw away (so if pieces of the sticky foam fall, you keep them on the plastic). Put the BeoLab on the plastic covered table. Use plastic hand gloves to keep your hands clean.
  2. Remove both the 'power supply/amp' and the 'speaker panel' units from the speaker casing.
  3. Start taking out the big foam pieces by hand, from bigger to smaller. Be carefull as they easily fall apart. I stopped using a vacuum cleaner, as the sticky parts maken it constipated, and you can throw away the vacuum cleaner. Make sure you also remove the foam pieces on and in between the components, and from the PCB's (both the component side as the side with the copper traces).
  4. Clean the last foam remains on the PCB/components using isopropyl alcohol (96% or up). I mainly use ear tips for this. This part is also time consuming.
  5.  What is left is cleaning the inside of the empty speaker casing, the aluminum part. To get rid of the last foam remains, I use natural vinegar and an old cloth. If you use the right vinegar, there are no chemicals in it. And vinegar is able to dissolve the stickyness of the foam remains.
Again, it is a lot of work. But it is do-able. Anyhow, not doing it with old BeoLabs that have this sticky foam, means high risk of a beautiful speaker that will get serious issues.
If you have PCB traces that are already eaten away, you will have to create a new trace. You can easily do that by using a wire. Normally you can see where the trace is supposed to be, so you solder the wire in such way that you reconnect the components that are in the PCB trace. I have had situations where the Auto Standby relais was malfunctioning because of this. Be aware that sometimes a PCB trace looks fine, but if you use a magnifying glass you can see that is partly 'eaten away'.
Hope this helps you.
gerard
Luxembourg
Posts 331
gerard replied on Mon, Aug 9 2021 5:03 PM
Thanks for the infos.
Surprised to hear that vinegar is not to much acid for the aluminium, good to know that it de solves the gluey foam.
My threat for the pcb trace and standby issue is here:
https://archivedforum2.beoworld.org/forums/p/34724/327855.aspx
KolfMAKER
The Netherlands
Posts 176
Silver Member
You are welcome.
Again, make sure the vinegar is a natural product without added chemicals.
And another thing, just put it on a cloth to remove the sticky foam. And immediately after it dry the aluminum with another (dry) cloth.
If you do not leave liquid, it will work.
PCB & dissolved traces: I have seen your thread, it is exactly what I did recreating the traces by wire.
smuehli
Ludwigsburg, Germany
Posts 105
smuehli replied on Wed, Aug 11 2021 8:30 AM
Thank you for this description.
Does this problem belong to any BL8000? I own the Mk 1.5 as I remember  (1995 or 1996) . . . .
Where can I order the new foam?
Are there any gaskets between the panels and the housing?
The trace(s) could be restored by soldering over the wholes, or not?
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Wed, Aug 11 2021 3:43 PM
You are welcome.
This problem does not belong to all BeoLabs 8000. B&O at some point changed the foam material they used. It is easy to recognize, as the good foam material is white and the old is dark brown. From experience I would say that a majority of BeoLab 8000 in 2nd hand oferings have the old foam. It might be that all Mark I have the old foam and Mark II has the new. But I am not sure.
The new type of foam can be ordered with B&O dealers. Sometimes you can find it on eBay. Though most offerings on eBay are $50 or more (excl. shipping) for only one set. I have bought with B&O dealers 2 sets for just €25. I think the article number is 3332084 00000001.
There is a gasket between the edges of the aluminum speaker casing, and the speaker panel unit and power supply/amplifier unit. This is thin and narrow double sided tape. Easy to find on aliexpress or banggood.
Yes, traces can be restored by soldering wires connecting the points of the original trace.
Beozip
Posts 368
Beozip replied on Sat, Aug 14 2021 9:31 AM
smuehli:
You can order from this Ebayseller in Germany/Berlin.
Make an priceoffer for the best price. I got a big discount Big Smile
https://www.ebay.de/itm/154203121912
good luck Smile
gerard
Luxembourg
Posts 331
gerard replied on Mon, Aug 16 2021 10:50 PM
KolfMAKER:
Hi @KolfMAKER,
I have this EVA sponge foam tape. 1mm thick.
amazon: https://www.amazon.de/Dichtungsband-Selbstklebendes-Schaumstoffband-Türdichtung-Schalldämmung/dp/B08P1R85GH/ref=mp_s_a_1_1?dchild=1&keywords=Dichtungsband+für+Türen+Fenster+2+Rollen+10m+x+15mm%28B%29+x1mm%28D%29+Selbstklebendes+Schaumstoffband+Türdichtung+Fenster+Schaumstoff+Klebeband+für+Kollision+Siegel+Schalldämmung&qid=1629150061&sr=8-1
Do you think this will do the job as gasket?
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Tue, Aug 17 2021 8:36 AM
@Gerard
The type of tape you refer to is fine.
The thickness of this tape is 1mm, which is thicker than the original tape used by B&O.
My suggestion would be to look for tape which is thinner, to a max. of 0,5mm.
You could use for instance use tape that is also used for repairing smartphones. It has the right material, strength and thickness for the BeoLab. And the thickness will be perfect.
For example: https://nl.aliexpress.com/item/4001247888018.html?spm=a2g0o.productlist.0.0.45e67ef2SuMEWj&algo_pvid=b7f3fce3-39b8-4c02-86c0-37ea26d607c9&algo_exp_id=b7f3fce3-39b8-4c02-86c0-37ea26d607c9-5&pdp_ext_f=%7B%22sku_id%22%3A%2210000015455192446%22%7D
MartD
Posts 3
MartD replied on Wed, Sep 15 2021 1:06 AM
Last weekend one of my beloved Beolab 8000's failed (red/green light ok, but no sound). Trying to find some clues, I stumbled on this thread and I am very grateful for the clear and knowledgeable info in this topic.
Indeed the failed BL8000 suffered from "foam rot". I removed it and thoroughly cleaned the speaker (what a mess!) and found a trace on PCB01 had been eaten away by the stuff. After soldering in a bridge, the speaker sprung back to life. Hurray!
Next task will be to clean the other BL8000 before it gets affected as well.
Of course I need to put in new foam damping material and I saw that you purchased these from a dealer. As I believe you are also in the Netherlands, could you indicate which dealer you bought it from?
Thanks and keep up the good work!
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Wed, Sep 15 2021 8:45 AM
Dear MartD,
Congratulations, that you have been able to resolve your issue with this information. That's great!
It is definitely a good idea to also treat your other speaker. Better to prevent than to cure.
The new damping foam is a standard B&O article, which you can probably get from any B&O dealer. My suggestion would be to try a local B&O dealer, that might be most convenient for you and saving shipping cost.
If you have trouble finding a dealer with the replacement foam, let me know.
MartD
Posts 3
MartD replied on Fri, Sep 17 2021 1:50 AM
Many thanks for your advice.I have ordered the damping material through a dealer as you suggested.
Once both 8000's are fixed, I will check my pair of Beolab 6000's. According to the dealer, these seem to often suffer from damage to the rubber speaker surrounds. There is quite some info available on the web as well as repair kits. To be continued!
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Fri, Sep 17 2021 11:44 AM
You're welcome MartD.
Yep, the rubber speaker surroundings of the BeoLab 6000 are almost always up te replacement after so many years. It has to do with the choice of material. I have replaced many in the meantime.
I can recommend the repair kits from AudioFriends (Dutch company). The kit for the BeoLab 6000 you can find here.
An instruction for how to it is here
Good luck!
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sat, Sep 18 2021 8:27 AM
Dear Smuehli, the problem does not belong to every BeoLab 8000. If you have a BeoLab 8000 set with white foam, this problem does not occur. B&O at some point changed the dampening foam, the white foam does not pulverise and start sticking to the PCB and electronics.
By the way, MK1.5 does not exist, there's only MK1 or MK2. If you share the serial number I can tell which one you have and what build year it has.
For the replacement foam, I advise to contact a local B&O dealership. That's the easiest and quickest way and prevents shipping cost.
For the gaskets you need certain double sided tape. If you scroll through this thread, you will find the info and links where to find it.
MartD
Posts 3
MartD replied on Sat, Sep 18 2021 5:48 PM
Both Beolabs 8000 have been cleaned, fixed and now have the new foam installed. They should be fine for another 20 years of service :-).
Fortunately, inspection of the Beolabs 6000 revealed that the speakers are still in perfect condition, no deterioration of the rubber rings.
All's well that ends well.
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sun, Sep 19 2021 11:15 AM
@MartD: well done!
KolfMAKER
The Netherlands
Posts 176
Silver Member
KolfMAKER replied on Sun, Sep 19 2021 11:17 AM
@dragonvid
If you look at page 1 of this thread, you will see a picture that shows all different pieces placed in position.
Hubert69
Posts 2
I just ordered the original damping material set from the local B&O dealer, only 10€ per set. Sound quality has hugely improved! It’s a universal kit for all BL 8000 models
Hubert69
Posts 2
Page 1 of 1 (29 items) | RSS
