Hi!
I have a pair of Beolab 18 connected to a Beosound Moment via wireless. I just wonder - do esthis give me the very best sound from the BL18? Will it be better with cables? Or perhaps to connect a Core instead of the Moment? Or does all B&O sources sound the same?
/Robert
I quite happy, but I think they could be more dynamic...the sound is a bit flat. And its not the lack of base that is wrong with the sound...just sounds a bit boring. The music I play is Deezer FLAC - and that sounds way better than Spotify over bluethooth.
Sounds like Core & Cables is a good way to upgrade the sound:)
/R
Robert_A:I quite happy, but I think they could be more dynamic...the sound is a bit flat. And its not the lack of base that is wrong with the sound...just sounds a bit boring. The music I play is Deezer FLAC - and that sounds way better than Spotify over bluethooth. Sounds like Core & Cables is a good way to upgrade the sound:) /R
Hmmm.. Not sure what's wrong..but I will try to connect a Beosound Essence to check if they will sound a bit more dynamic, Take for example Billie Ellish - When the partys over - there is no bass, and then I mean not at all in the chorus (0:50 - 1min). It sounds more like a very gentle acoustic version.. Strange that they don't try to play as low as they can rather than cutting all the bass away?
Yup, I'm planning to add a BL19 . that will help👍🏻😊
I know I mentioned that the problem wasn't the lack of bass...but maybe it is🤷🏼♂️
Robert_A:Hmmm.. Not sure what's wrong..but I will try to connect a Beosound Essence to check if they will sound a bit more dynamic, Take for example Billie Ellish - When the partys over - there is no bass, and then I mean not at all in the chorus (0:50 - 1min). It sounds more like a very gentle acoustic version.. Strange that they don't try to play as low as they can rather than cutting all the bass away? Yup, I'm planning to add a BL19 . that will help👍🏻😊 /Robert
This is how I check bass.BL2 sounds excellent
https://www.youtube.com/watch?v=t_6uRz-x1WE&list=PLeDJ1F3W5GgK5ElUo6ASdG4o6lpvH_pz7&index=3
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Thanks for the information keep sharing such informative post keep suggesting such post.
OneVanilla
