Beosound Ouverture - Tapedeck problem with spring
Vintage_B&O
Germany
Posts 303
Vintage_B&O Posted: Sat, Mar 13 2021 12:01 PM
I need your help. I am currently reworking a Beosound Overture and have swapped the belt on the cassette deck. But now I am no longer sure how the spring has to be adjusted. Unfortunately, when I slide it into the holder, the coils no longer turn. Is there a trick here?
Vintage_B&O
Germany
Posts 303
Here is a photo of the spring.
Vintage_B&O
Germany
Posts 303
The problem is that once installed, the spring blocks the sound head when it goes up. Behind the spring is a small metal ball and the spring is to the front. And there is no lock on the right side.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Mar 13 2021 3:15 PM
The metal plates two arms should rest on the forward edge of the capstan bearings - not on the capstan spindles.
The plate holder has broken at the right side, you will have to glue it back onto the black plastic as good as you can.
Page 1 of 1 (4 items) | RSS
