We have just bought a 2nd hand Beovison 10 32 in to replace an older TV. It came with the stand but without the M5 bolts to attach it. Anyone know where we can get them? Tried our local store but unable to order them anymore.
All help appreciated!
A hardware store?Ebay?
We have tried about 20 different types of M5 10mm bolts but the thread pitch was wrong each time. The stand hole strips the thread from the screws.
Do they fit into the TV if you try them without putting them through the stand? on mine they pass through through the stand so maybe you need smaller ones?
