Hello everybody. I would like to buy a Beogram with tangential arm, white color, as my furniture. I would like to get it fully restored.
Which model do you recommend to look for (5500/6500/7000)?
Do you know any professional who sells restored / overhauled products?
Thank you all.
Hi Sly,
I don’t know if one works better then then the other, i have the 5500 and i just love it. Works perfect for me.
i saw this post and in came by this in Belgium. Maby something for you..
https://link.2dehands.be/m1658226834?utm_source=ios_social&utm_medium=social&utm_campaign=socialbuttons&utm_content=app_ios_tablet
I have 6500 with MMC2 for more than 25 years,still sounds perfect to me.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
They are all the same. Except that the 6500/7000 has the RIAA amp. built-in.
/steffen
Are you using it with a B&O system? These decks are remote control but only when attached to the relevant Beomaster. The point above is important - the 6500 and 7000 will produce a line level signal which can be sent to almost any device. the 5500 will require an external RIAA amplifier. The Beogram 4000 and 8000 series also came in white and the 4000 is particularly beautiful.
Peter
