I have owned a beomaster 4500 system for 15 years. Wall remote in one room does not work speakers not functioning. Ideas To change wall remote
Check the option setting first. It may possibly have been set to Option 0 so the remote won't work - What remote do you use and what speakers do you have. I suggest the following. In the link room, if you have a Beolink 1000, press standby, Sound, 2, STORE. The red light on the MCL wall sensor should flash.
Peter
