Hi everyone,
I have received a Beolit 606k or 606 as a gift (I am not sure which one of them it is). I can hear that there is life in it when I press the buttons but it is only noise. Do i need to buy and plug in an external antenna? Or does anybody know how to make it work?
best regards
Charlie
I would check the DC levels around the IF-transistors as the first thing.
Hi Martin,
Thanks for answering.
As i am lacking some technical skills i need some more specific details :)
What does the DC levels look like and where is it located? Thank you in advance.
