Beolink Converter NL/ML latest installations guide
This post has 5 Replies | 0 Followers
Abakus2007
Posts 68
Abakus2007 Posted: Fri, Mar 26 2021 9:28 AM
Good day all,
have searched and found version 1.4 on the forum but there should be later (or diffrent) versions
as this one does not correspond with the actual menus on my blc nl/ml.
In the configuration menu there is no section with app setting which seems to be an evolved
version of BNR alias.
The software version on mine is 1.4.3.19816, which I'm told is the latest.
Thanks in advance
Baaz
Abakus2007
Posts 68
I know there is a beolink guide 1.7 but that one does not really show the menu settings more a guide for different setups.
Baaz
lawrencejmcook
Posts 742
Hi Baaz - thanks - I didn’t know there was a version 1.4 (I had 1.2).
I’m afraid I don’t have a later installation guide to offer, but I thought I should tell you that the software version of my NL/ML converters is 1.4.3.19864.
Lawrence
Abakus2007
Posts 68
Thanks Lawrence,
You´re right, I have automatic update active but when I manually check for latest version Yours appear.
Did not manage to install that, will keep on trying.
Here is a link to version 1.4:
https://www.dropbox.com/s/r7hkg4p9t8f1sfo/BeoLink%20Converter%20NLML%20%28ver.%201.4%29.pdf?dl=1
Baaz
lawrencejmcook
Posts 742
Thank you, Baaz.
I have 2 BLGWs sitting in boxes. I tried installing one once, struggled with the interface and packed it away.
Once I unpack some more of my collection (incl. a couple NL/ML converters) I’ll have another go. I’m more interested in the macro facilities than non-B&O control. I wish we had a pinned BLGW beginner’s guide on the forum.
Abakus2007
Posts 68
Abakus2007 replied on Sat, Mar 27 2021 11:35 AM
Lawrence,
the BLC makes me confused, the BLGW I thought was a bit more straight forward at least with
my, so far, not so complicated setup: rooms - products - sources(beo4 buttons)
Macros will be the next step.
A BLGW for dummies would still be helpful though and for BLC as well.
I think there is a big progress with the guide 1.4 compared with 1.2, it explains in
more detail the settings and the differences between the modes, more educational.
Good luck
Baaz
Page 1 of 1 (6 items) | RSS
DigiCert Secured Site Seal
