MX6000 doesn't start up
Mauritss
Posts 1
Mauritss Posted: Sun, Feb 3 2013 7:49 PM
My B&O MX6000 recently stopped working after 20 years without problems.
The TV was on for a while and it suddenly flashed out. It didn't flash out similar as it used to when I used the remote control, but like a really old tv: the image shrank to the middle of the tv with a green glow and with a strange noise. But it wasn't really a BANG.
I tried to turn on the TV using the remote control but then the LED flickers from red to green for a second, but then flickers back to red.
Then I pulled out the switch-plug and put it back in after 5 minutes. Then the TV was able to start up and give image for 1 to 2 minutes and then flashed out again.
I opened my TV carefully following these instructions, to see if there were any leaking caps or disconnected wires.Without any result. I've removed all the dust using a vacuum cleaner.
In the serice manual I've found that the TV uses a safety circuit to protect the TV in case of problems. But the detailed origing of the problems aren't specified.
My question to you: do you have any idea/suggestion the help me further?
(I've seen a list of caps that are common to cause problems, but because I'm not an electronic expert, I think it's too tenuous just replace these and hope it will work)
Edit:
For clarity, I made a video of the problem:
http://www.youtube.com/watch?v=5cOeSSL-ZaE
The short period the TV turns on only occurs when the plug was out for a while, once turned on and flashed out: the red light only blinks to green and back to red when you try to turn on the TV directly after.
Page 1 of 1 (1 items) | RSS
