Hi All,
i am sitting over my Beogram 4000 trying to figure out the carriage control issues:
just replaced all TO93 transistors in the H-bridge of the motor control circuit - all had issues and the carriage wasn't moving at all.
Just wondering how critical it actually is to perfectly match those transistors TR31/30/29/28 ??
transistor TR29 should be a BC144 as per SM, however I only had a BC142 at hand ?!
the carriage moves again but is showing some strange behaviour.
When it is moving out to its resting position the BG turns off but the carriage immediately moves back, travelling in, just enough to turn on the BG again ??
In other words, as it stands I can only turn off the BG by unplugging it from the mains. It almost appears as it would get another Start-up Impulse ?? But how ?
Could someone explain or provide me with a pointer ??
thank you kindly
ALF
Ok,
As one should in a next step, I tried to verify the 6V and 24V supplies are present !
on the main board #1 I have 6V present but the 24V are infact 32V, depending on status ON, arm not lowered or OFF ??
the 24V supply is nowhere to be found: not at C of 2TR7, not at E of 0TR1, not at the SO switch on board and not at 2MS1 (reed relay) on board 2 ???
but isn't 0TR1 generating the 24V for the reed relays ? If so, either 0D1 or 0TR1 must be faulty ?
does that sound correct ?
thank you once again for your inputs
Well, another session with testing components:
0TR1 tested fine and so did all the other transistors from the Power supply board #2
the carriage goes back to its ES but : the BG does not completely turn off - 3IL3/4 are still on !!!
as described earlier, when the carriage reaches ES it immediately travels back in a very short distance (about 1cm)
there should also be a 24V point at one of the Reed relays ? I measured their coil resistance, showing about 293 ohm.
i haven't checked their glass-tubes yet, however the outer glass tube from 2MS1 showed a constant 'OL' when I measured continuity,
meaning its contacts are open.
so, a couple more issues to further investigate......
anyone in a position to help ?
thanks, ALF
A shorted Reed-relay element?
Yes, thank you Martin - that's a possibility !
I ordered a set of the reed glasstube switches as the ohm measurements in ON/Off state are inconclusive.
Good lead to follow up.
apologies for the long delay but thanks to the corona crisis postal services are slower than a snail's pace.
the new glass reed switches finally arrived and were installed in one of the reed relays. That itself wasn't a big issues, however during
the "surgery" one of the micro-thin coil wires detached itself from its post 😡
so, after micro-surgery I managed to reattach that wire, checked the coil resistance to be sure contact had been established...yes !
time for a test run: nothing....dead !
after checking the fuse box it turned out firstly two wrongly rated fuses were installed and one fuse died - easy fix, fitting the correct fuses and.....
turned on the Beogram and all seem to work again 🙏🤩
the carriage moves in and out, the arm lowers at the drop down point and carriage moves out to its resting point and unlike before the Beogram
Now switched off again.
isn't it nice when everything works again, be it only for a while 😁 until the next drama unfolds.
Interested parties will know how complex that table is and the serious headaches it can inflict.
i am signing off for now - thank you Martin and all other interested followers.
PS: don't damage those reed relays !!
Hi ALF,
Could you perhaps go into more detail as to how you reattached the coil wire from the reed relay?
I've been working on a broken Beogram 4000 for quite a while now and I'm a complete novice. I accidentally removed a coil wire from the reed relay, as I thought it was a wire I had dropped in the circuit...
Hello Gaderaden,
sorry to hear about your mishap !
well, it all depends where your reed wire detached ?
mine detached at its designated pin and what I did to bridge that tiny gap between the wire-end and the pin was
attaching a “pin extention” like an additional short arm reaching out to the wire and bonded both ends together !
as you will have noticed that wire is incredible fine, almost invisible and soldering is - if possible at all - like micro surgery.
if the wire hasn’t broken off too close to the relay’s body you can try the same method adjusting the length of that “pin extention” as required.
another suggestion may be using a tiny drop of soldering paste (like used with smd soldering) ?! The wire would stick and so would you pin extention.
heat will solder both ends immediately.
if that doesn’t do it you are looking at the aweful task of recoiling the relay - our member Sonavor has posted an excellent thread about that very issue.
best of luck with the surgery
ALf
Hello ALF,
Thank you for the quick reply.
It was the wire from the top coil connected to the pin "behind it", so to speak (to the right). I had tried extending it with no luck, so instead I tried to unwound more wire from the coil.In that process however I managed to break one of the rods going through the coil (the glass in the one end broke).
Something changed however... I wasn't able to get anything working before but now the motor for belt is running as soon as the power is connected. I just can' switch it off and nothing else can be turned on...
Maybe I'm looking at recoiling afterall... I'll check out Sonavor's post.Thank you for the tip!
Best regards,Kristian
I didnt know Sonavor has a thread on re-winding the switch coils.......will have to have a look, has to be a tricky operation
Hi Kristian,
that is very u fortunately - you damaged one of the reed glass switches - now you seem to have permanent power because it can’t switch off.
the reed glass switch (those glass tubes) can be purchased - you may have to google it though - I had exactly the same disaster and found some replacements from an Australian supplier.
rewinding the relay coil is unfortunately not much fun - luck had it that I could bypass doing that. There are really not many alternatives except finding
a spare power supply board with intact relays.
you can always try member Dillen (Martin) - he might have a spare relay ?? No harm in asking.
unfortunately there seem to be no suitable modern relays which could replace those ancient old reed relays.
Very sorry that I can’t be of further help 🥲
be positive, you will succeed with persistence ! 🤞👍
Yeah, I was probably not as careful as I could have been... These are the things you learn from, I guess!You have definitely been of much help. I didn't really know where to go before but I have a good sense of my next steps now thanks to your input.
Hopefully I will have some pictures for the Beogram 400x restoration thread in the future!
/Kristian
