Beoplay Portal gaming headset.
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Great, I have been waiting for these for ages.
Subtle and nice, no RGB lighting, and apperently not a visable microphone?
Hope they also will work with PS5 lets see tomorrow,
Where did you find these pics Anderson?
The HX you cannot use for gaming, because when you use the Microphone the sound setting change to speak, and therefore terrible to use for gaming.
Finally it will be posible with the Portal.
Emil Jensen:The HX you cannot use for gaming, because when you use the Microphone the sound setting change to speak, and therefore terrible to use for gaming. Finally it will be posible with the Portal. Beovision Harmony 77" 2nd Gen, Beolab 5, Beolab 17, Beosound 1, Beoplay M3, Beoplay H6, Beoplay Earset, Beoliving Intelligence
mr_anders_son:Beoplay Portal gaming headset. BeoVision Eclipse 55"...BeoLab 5 FRONT....BeoLab 4000 as REAR....BV5 HD....Beoplay V1-40....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Google translate:
"Packed to the brim with dedicated gaming features, Beoplay Portal offers i.a.
fast and solid connection for wireless gaming, Dolby Atmos virtual surround sound for
headphones for an immersive and precise gaming experience, excellent microphones
for clear speech, digital active noise reduction for effective sound insulation and much more.
With our signature sound and design, we strive to offer an engaging, high-quality sound experience for games, movies and music.
Beoplay Portal is developed for gaming, but designed for life."
https://www.youtube.com/watch?v=pDxR-wXexgo
Here you go. All details
There you DON’T go - you need a login for that page.
This is the only one, I have found:
https://youtu.be/UdjzmtZ39J8
Millemissen:There you DON’T go - you need a login for that page. This is the only one, I have found: https://youtu.be/UdjzmtZ39J8 MM There is a tv - and there is a BV.
the Link worked before,
Clearly the launch time have not been well communicated, not the first time.
Bestbuy have it online on their webshop.
At 15 a clock Danish time we will see it everywhere.
I must say that I am very hyped for this.
Much cheaper than I had heard, and much better looking than I had hoped.
So win win,
Only thing can it be used with PS5?
Article at The Verge here
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
And on the B&O website now:
https://www.bang-olufsen.com/da/hovedtelefoner/beoplay-portal?variant=beoplay-portal-xbox-anthracite
Newly haircutted John o’ Manchester already tested the Portal
https://youtu.be/pDxR-wXexgo
It really pisses me off how these are so much better in pretty much everything compared to the HX, and yet they cost the same.
And how exactly are they so much better? I'm probably missing something in the specs?
Battery life seems to be worse..
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Is that the case for the H95’s also?
Emil Jensen: The HX you cannot use for gaming, because when you use the Microphone the sound setting change to speak, and therefore terrible to use for gaming. Finally it will be posible with the Portal.
crossbytje: And how exactly are they so much better? I'm probably missing something in the specs? Battery life seems to be worse..
Technically and technologically, they're on another league.
Lossless and latency-free 2.4GHz connection (on Xbox and Windows).
Virtual Dolby Atmos processing.
Much better hardware controls.
Much better ear cushions.
Customisable 5-band EQ (how long for we've been asking B&O for this, on the H series?).
Probably better microphone algorithm (or even better mic hardware).
Microphone works also via 3.5mm jack and via USB-C connection (with HX it only works via BT).
Plus all the stuff the HX come with (Google Fast Pair, Bluetooth 5.1, Microsoft Swift Pair, aptX Adaptive, etc). The only things that the Portal lack are the wear sensor (that go figure, B&O don't even advertise for the HX) and the included carrying case (plus, better battery life, despite the larger battery that B&O put in Portal and that also could have put in the HX especially as unlike the H9 series they can't be used passively - battery that most certainly would have fit since the HX lack all the additional hardware the Portal have that's related to the 2.4GHz module).
And Portal are even slightly lighter than the HX (despite additional hardware and slightly larger battery).
All of this, at the same price of the HX.
Yes, battery life is better on the HX, but they come with the same battery as the H9 3rd Gen, which shows how little effort B&O put in the development of the HX. Also look how much they're advertising them (zero). Look at how much they're advertising the Portal.
HX are probably an old project that was in development before they agreed what to do with the partnership with Microsoft, so they just quickly released them without giving much importance to it. It's basically the exact same hardware as H9 3rd Gen, with slightly updated design and Bluetooth module borrowed from the H95.
I wouldn't be surprised if HX are the last model of the H headphones series.
They'll keep H95 going forward with updates, and that will be the premium "music" headphones for who wants to spend a lot of money for music headphones, and they'll keep the Portal line going for who wants to spend less.
HX are not as profitable for them as the H95 and Portal are.
Then again, I haven't heard how the Portal sound compared to the HX, but still... I doubt the drivers are different from the ones of the HX (and hence, H9 3rd Gen), if there's any difference in sound it's 99.999999% likely due just to different DSP tuning.
@Beo_Vision: yes, also H95 are affected by that "issue". And even the Portal if you use them in Bluetooth mode.
A very positive review:
https://www.techhive.com/article/3613118/beoplay-portal-headphone-review.html
Beomaster 1700, Beocord 8000, Beolab 4000 MK1, Beolab 3000 (passive flat panel), BeoPlay E8 3rd gen, Beoplay H9 3rd gen, Beoplay P2
A longer review here........he is quite excited about the Portal
https://youtu.be/Ri-I7y7DfUk
Has anyone tried both the Portal and HX — and I guess H95 too as an added bonus — and can comment on long term comfort? Any difference?
I’ve always been more of a speaker girl because the vast majority of headphones don’t really seem to work for me in terms of comfort; but with work-from-home being the norm I also need to be mindful of my partner whom I share my home with so I’ve been looking at headphones again.
As another point of reference I used to own a Bose QC 35 II but sold them because I couldn’t wear them for more than an hour. My personal benchmark for comfort is the Sennheiser HD800, but I got rid of those because I didn’t really appreciate the additional clutter involved with having an external amplifier plus I didn’t really enjoy being anchored down to my desk by a cable.
I don’t have the opportunity to visit a dealer to try these newer headphones out so I’m really looking for good advice especially from anyone who has experience with any of the headphones I have. I really love and prefer the simplicity of the Portal’s design but comfort comes first.
Added bonus points for anyone who has actually worn them for hours at a time because it’s one thing to try some headphones on at the dealer for 15-30 minutes but an entirely separate matter to have them on your head for half the day.
Also while I’ve got plenty of experience with B&O speakers I’ve never owned any of their headphones before.
Hi, has anyone preordered these in the UK? I have, the delivery date was 15/04/21 which has now passed and no joy. Anyone know then they’re going to be released? Thanks
Pic499: Hi, has anyone preordered these in the UK? I have, the delivery date was 15/04/21 which has now passed and no joy. Anyone know then they’re going to be released? Thanks
Yes the same here, but they were delayed to the 29 April,
I choose to wait for the grey mist which arrive the 6 may.
Sadly everything is delayed in these times, not only b&o :(
Cheers Emil
Millemissen:A longer review here........he is quite excited about the Portal https://youtu.be/Ri-I7y7DfUk MM There is a tv - and there is a BV.
has anyone got to try them?
Massimo
For the curious Rtings in Montreal has done a very objective review of it with a lot of measurements.
https://www.rtings.com/headphones/reviews/bang-olufsen/beoplay-portal
I'm particularly impressed by the measured wireless latency in the Xbox Wireless mode (which you can also use on a windows computer with the xbox USB adapter), just 19 ms! That should be undetectable to the human ear.
The older H9i is also reviewed there, here is a side by side comparison:
https://www.rtings.com/headphones/tools/compare/bang-olufsen-beoplay-h9i-wireless-vs-bang-olufsen-beoplay-portal/813/24039?usage=20&threshold=0.10
double post
Did a video on them with an Atmos example: https://youtu.be/jAaMUnK-zAg
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
