Hello, a little problem with tape 1 non my Beocenter 9500:
I noticed that the turn function doesn’t work . When I press the turn button , tape engages the other side but after few second it return to original side. So the auto-reverse function doesn’t works. Suggest me further control to resolve this matter.
All other functions worls well (play, FFw, RW..)
Thanks.. Ivano
Most likely a brake that doesn't release properly.
Hi Martin, but where I must check properly?
Ciao
